Honda S2000 Honda S2000
ARC Air intake box
Old Oct 23, 2006 | 10:31 AM
bliss@5200's Avatar
Default ARC Air intake box
Does anyone have this intake or any knowledge of it beause im looking into purchasing it but i know nothing about it. Is it worth the 700 bucks? and our the gains that much better?
Heres the link to it if want.
http://www.modacar.com/product....html
Old Oct 23, 2006 | 10:34 AM
cmdr430's Avatar
Default Re: ARC Air intake box (bliss@5200)
It is a good intake for higher speed intervals......
otherwise it gets heat soak pretty bad.....
Old Oct 23, 2006 | 11:11 AM
orangebarius's Avatar
Default Re: ARC Air intake box (cmdr430)
its not worth the money and the heat soak is bad as mentioned above. its a total bling factor piece.
Old Oct 27, 2006 | 09:45 PM
MidwestAutoWorks's Avatar
Default Re: ARC Air intake box (orangebarius)
heat soak
spend the 700 on nitrous
Old Oct 27, 2006 | 11:02 PM
LAS2K's Avatar
Default Re: ARC Air intake box (MidwestAutoWorks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MidwestAutoWorks &raquo;</TD></TR><TR><TD CLASS="quote">heat soak
spend the 700 on nitrous</TD></TR></TABLE>
lol and watch your car go boom boom bye bye
Old Oct 29, 2006 | 07:50 AM
Splitduration94's Avatar
No, it's not really an EG6. I just like to pretend.
Default Re: ARC Air intake box (LAS2K)
So if the ARC has heat soak issues, how does the J's intake do??
Im thinking about taking out the ower baffling on my stock box, throwin in a k&n or green filter and getting a CF cooling plate...
Old Oct 29, 2006 | 08:20 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LAS2K &raquo;</TD></TR><TR><TD CLASS="quote">
lol and watch your car go boom boom bye bye</TD></TR></TABLE>
you have to use your head when you use n2o, there's plenty people are running n2o around.
Old Oct 30, 2006 | 10:06 AM
XLevel's Avatar
Default Re: ARC Air intake box (iam7head)
The J's intake is also more of a bling piece, but it also performs well. If it's dynoed HP you want, you should be looking at AEM's V2. It sits around 8 inches above the ground on a stock S2K, so you shouldn't have any problems with water if you are smart about driving your car. Also, don't soak the area around the filter cut out with a ****-load of water. I specialize in S2K parts and you can find me on S2KCA and S2Ki. I would PM you, but this **** board won't let me do crap.
Old Oct 30, 2006 | 10:45 AM
JDM knowledge's Avatar
Default Re: ARC Air intake box (XLevel)
gets heat soak. Just for bling. Its nice. I wouldnt buy it. 4 words or less.
Old Oct 30, 2006 | 02:27 PM
WowOzYouRock's Avatar
nitrous doesnt blow up engines ... people who uses nitrous incorrectly blows up engines
Old Oct 30, 2006 | 04:11 PM
Nishant's Avatar
Default Re: ARC Air intake box (FR-MOB: Jerk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FR-MOB: Jerk &raquo;</TD></TR><TR><TD CLASS="quote">nitrous doesnt blow up engines ... people who uses nitrous incorrectly blows up engines </TD></TR></TABLE>
i agree with the noob
Old Oct 30, 2006 | 10:27 PM
LAS2K's Avatar
Default Re: ARC Air intake box (Mr. Nishant)
ya i was referring to the nub who said put the money towards the nos. typical nub first answer.
Old Nov 2, 2006 | 10:34 AM
j-werk's Avatar
what about the spoon airt duct? anything good on that? any water problems?
Old Nov 2, 2006 | 12:44 PM
LAS2K's Avatar
Default Re: (j-werk)
not much water problems as it does not dip to the ground as much as the v2. its more of a heatsoak prevention.
Old Nov 7, 2006 | 04:57 AM
b18c4door's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by XLevel &raquo;</TD></TR><TR><TD CLASS="quote">The J's intake is also more of a bling piece, but it also performs well. If it's dynoed HP you want, you should be looking at AEM's V2. It sits around 8 inches above the ground on a stock S2K, so you shouldn't have any problems with water if you are smart about driving your car. Also, don't soak the area around the filter cut out with a ****-load of water. I specialize in S2K parts and you can find me on S2KCA and S2Ki. I would PM you, but this **** board won't let me do crap. </TD></TR></TABLE>
Do you lose throttle response with the AEM? Air boxes generally help with midrange throttle response (BMW, etc) and I wondered if the AEM was only a high rpm power producer? Thanks!
Old Nov 7, 2006 | 05:34 AM
Curiouz_G's Avatar
personally i think the stock airbox does more than a good enough job. its design is already a "cold air intake" design so theres really no need to change it except for the bling factor
Old Nov 10, 2006 | 07:30 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Old Nov 13, 2006 | 05:48 PM
kito858's Avatar
I actually have both piece of the ARC, and yes its a heat soak, but once the car gets movin, u can feel the gain and the engine response. I saw someone online that had ARC and covered it with some sort of heat resistant cloth or watever, but the person was sayin that it runs better. But thats already an expensive intake and spend more money on heat resistant stuff, its too much.
Old Nov 13, 2006 | 06:05 PM
bliss@5200's Avatar
Default Re: ARC Air intake box (kito858)
thats exactly the responce i was looking for.... i think im going to do a V2 CAI since i just bought my S2k a couple days ago
Old Nov 13, 2006 | 06:20 PM
kito858's Avatar
*edited for parts slinging*
final warning
Old Nov 13, 2006 | 06:32 PM
bliss@5200's Avatar
i will think about it... ive kinda been leanin toward the v2 just because its 250 less and it does basically the same thing. ill keep ya updated though if i change my mind cause i do like the way they look under the hood, i just hate heat soak its pretty annoying
Old Nov 13, 2006 | 09:10 PM
Jet.'s Avatar
I used to have this intake. I felt a bit more throttle response, but for the most part, it's mostly BLING!
Old Nov 13, 2006 | 11:36 PM
Weifast's Avatar
Eh, not worth the 700 dollars unless you got that type of money lying around somewhere and don't mind spending it for the bling factor under your hood. It does look nice, but if you're lookin for an excellent mod and the most bang for the buck, I can't stress swapping out the final gear ratio enough on the S. Best mod you'll ever get for the S compared to anything else.
Old Nov 14, 2006 | 05:08 AM
WhiteAP1's Avatar
Default Re: ARC Air intake box (Weifast)
If u want to get ure moneys worth,listen to Weifast, change your final drive, i love my 4.77. In regards to intake, unless ure willing to part with the $$$$ for J's or mugen dont bother with anything else. OEM is better than a pod on a stick anyday IMO.
Old Nov 15, 2006 | 04:33 PM
So what are you guys suggesting? AEM V2 or Comptech or ARC?
I heard its allmost the same thing if you do a KN filter and a Cooling plate/Spoon Snorkel...
Does this work- Or should i do one of those 3?
