Help! Car Revs to idle, then bogs. When warm, works normal. No CEL. What is wrong?
Old Oct 23, 2006 | 09:38 AM
francisco's Avatar
Default Help! Car Revs to idle, then bogs. When warm, works normal. No CEL. What is wrong?
Revs to idle (idles bad, but at a steady RPM), when gas is pressed, it bogs. When warm, works normal. No CEL, what is wrong?
1996 Civic Coupe Ex with B16a3 engine (obd2), intake, exhaust, msd box, external coil.
The car starts and goes to idle, but if you press the gas pedal it will bog and bog and not rev. If you leave it be for a while until it is warm, then it will go back to "normal operation". Revving fine and so on.
- Gas tank has been dumped
- there is spark
- timing belt has not jumped
- dizzy seems to be ok.
- exhaust was removed to test for clogged cat
HAVE SEARCHED, but the kicker to this problem is
1- No Check engine light
2- It goes away when warm.
Thanks,
Francisco
Modified by francisco at 10:55 AM 10/23/2006
Modified by francisco at 10:59 AM 10/23/2006
Old Oct 23, 2006 | 09:52 AM
fmrprojects's Avatar
Default Re: Help! Car Revs to idle, then bogs. When warm, works normal. No CEL. What is wrong? (francisco)
in for an answer. my car does the same thing if i start it up and drive it right away
Old Oct 24, 2006 | 01:27 PM
francisco's Avatar
bump for response
Old Oct 30, 2006 | 10:44 AM
francisco's Avatar
still looking for help... friends car is still stuck at the shop... we do not know what it is...
Old Jan 10, 2007 | 12:11 AM
Stoich EG2's Avatar
my car does this! help!
Old Jan 14, 2007 | 10:16 PM
ckyfan87's Avatar
Default Re: Help! Car Revs to idle, then bogs. When warm, works normal. No CEL. What is wrong? (Stoich EG2)
I just unplugged my throttle position sensor.... have yet to find a GREAT solution. This will work for the idle and bog problem just dont get on it until it gets warm!!
Old Jan 15, 2007 | 02:40 AM
ozz9955's Avatar
This may sound a bit condesending but...Don't ALL B16's idle funny? I know a B16A with B16B cams that idles at 5K revs...be thankfull yours isn't like that
I don't know whether this is the case...but at the last meet - everyone started up their cars (everyone with B16's) and they all idled at around 2K untill warm - could just be the British weather though!
Old Jan 15, 2007 | 11:20 AM
byronl's Avatar
my jdm d15b does the same thing except for the idling part, it does the same exact thing for the bogging part. Bump for a resolution
GunSamir
Honda Civic (2001 - 2005)
27
May 31, 2014 09:06 PM
simplegreenmachine
Jan 3, 2006 08:48 PM
stockegsix
Jul 28, 2004 05:33 PM
uszcrx
19
Jun 19, 2003 04:27 AM
B18C-RnVA
Mar 5, 2002 08:35 PM
