Bad dizzy?
Old Oct 23, 2006 | 08:57 AM
looxs's Avatar
Default Bad dizzy?
Can a bad dizzy lead to a flucuating idle?
Old Oct 23, 2006 | 09:16 AM
KingDanOne's Avatar
Default Re: Bad dizzy? (looxs)
it did with me... it was only the rotor though, it was really loose
Old Oct 24, 2006 | 12:15 PM
looxs's Avatar
Default Re: Bad dizzy? (KingDanOne)
how can u tell if the rotor is loose and how do u fix it? thanks
Old Oct 24, 2006 | 12:17 PM
65stang90crx's Avatar
Make sure that the little screw is tight.... If it is then make sure there is not shaft play by grabbing it and wiggling it, if it moves a good bit it needs replaced.
Old Oct 24, 2006 | 01:08 PM
CRX Toad's Avatar
Default Re: Bad dizzy? (65stang90crx)
Also replace cap, wires and rotor. And not with aftermarket crap get HONDA OEM!
Old Oct 24, 2006 | 02:37 PM
looxs's Avatar
Default Re: Bad dizzy? (CRX Toad)
so i pop off the black cap and i should see this screw?
Old Oct 24, 2006 | 02:46 PM
looxs's Avatar
also the it sounds like there is an occasional sqeek coming from the distributor... I popped off the black housing to see if there was any red residue showing a bad bearing but there wasnt. Do u think it is the bearing or should i replace my cap and rotor? What cap and rotor parts can i use for an obd0 b16 dizzy from honda?
Old Oct 24, 2006 | 03:22 PM
Furyof4's Avatar
90-91 integra cap and rotor
If it squeaks at all, the bearings are going bad in the dizzy. If your handy and have a local bearing place, you can just remove and replace the bearings. Otherwise just buy a new distributorking dizzy and be done with it.
Old Oct 25, 2006 | 08:17 AM
looxs's Avatar
Default Re: Bad dizzy? (Furyof4)
alrite thanks
White_EG1
12
Jul 16, 2015 08:16 AM
iwantspeed
Dec 24, 2007 03:38 PM
Extreez
Jan 3, 2007 04:33 PM
b18cEF9
Aug 27, 2004 11:21 AM
SouLaQuaRiuS
May 14, 2003 07:47 PM
