Cometic head gasket is junk!!!!
Old Oct 23, 2006 | 06:18 AM
Dark_Teg's Avatar
Default Cometic head gasket is junk!!!!
I was all set to install the head on the block last night and torque it down. I installed the ARP head studs and test fit the Cometic gasket. The two rivets on the intake side do not clear the block. Evidently the solution is to remove the two rivets and proceed. Why in the Hell would you knowingly manufacture a gasket that has rivets on the crush area of the gasket that have to be removed?
I have never seen such a high dollar POS in all my life.
Cometic
I am learning the hard way that with a Honda OEM is best!!
Old Oct 23, 2006 | 06:59 AM
GSRCRXsi's Avatar
Default Re: Cometic head gasket is junk!!!! (Dark_Teg)
i had zero problems w/ mine. did you order the right gasket? and it even says in the instructions to remove all rivets that are in the crush area.
Old Nov 1, 2006 | 09:31 PM
dunkd's Avatar
Are you sure you installed the headgasket the right way? Or have the right gasket. I wouldn't use it if you hacked it up like that.
Old Nov 1, 2006 | 10:11 PM
PyroProblem's Avatar
Default Re: (dunkd)
I had to do the same to my rivets as well. I also had to enlarge the dowel pin holes in the gasket cause they were too small...
Aftermarket parts often are not truely "bolt on"
Old Nov 1, 2006 | 10:35 PM
92TypeR's Avatar
FSAE
Default Re: (PyroProblem)
Weird, I've had 4 Cometics with no problems fitment or otherwise.
Old Nov 1, 2006 | 11:17 PM
unknown0001's Avatar
Default Re: (92TypeR)
Does anybody know the cometic phone number? the numbers on their site don't work for me
Old Nov 2, 2006 | 12:35 AM
fmrprojects's Avatar
Default Re: (Mr.RHTuner)
i have friends that used cometic and they all worked fine. me personally i use oem
Old Nov 2, 2006 | 02:20 AM
hybrid_vtec's Avatar
Default Re: (fmrprojects)
I use cometic head gaskets and have used four on 2 of my own motors and never had a problem with them. I think you are installing it backwards or have the wrong gasket. Verify the part # on yours to the recommended one on the website. You may have been sent the wrong one.
Old Nov 2, 2006 | 05:20 AM
Forrest Gump 9's Avatar
Default Re: (hybrid_vtec)
weird, I have use countless Cometic HG and never encounter such problem. Are you sure you have the right HG?
Old Nov 2, 2006 | 06:50 AM
Dark_Teg's Avatar
Lol,
I am not installing the gasket wrong and it is the correct gasket. The two rivets on the intake side do not clear the block. The gasket is impossible to install wrong since it says up on one side. I called Cometic and they say drilling out the rivets is how you install it and that its nothing to worry about.
I went with an OEM gasket and its all good.
I still have the Cometic gasket hanging on the wall in the garage. Its a $90.00 decorative ornament now.
I almost bought Cometic gaskets for my Talon Tsi and my Mustang thank god I didnt.
Old Nov 2, 2006 | 07:05 AM
VVV's Avatar
VVV
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dark_Teg &raquo;</TD></TR><TR><TD CLASS="quote">I was all set to install the head on the block last night and torque it down. I installed the ARP head studs and test fit the Cometic gasket. The two rivets on the intake side do not clear the block. Evidently the solution is to remove the two rivets and proceed. Why in the Hell would you knowingly manufacture a gasket that has rivets on the crush area of the gasket that have to be removed?
Cometic
I am learning the hard way that with a Honda OEM is best!!</TD></TR></TABLE>
same problem encountered here and many of my frens too....
Old Nov 2, 2006 | 09:59 AM
d16dcoe45's Avatar
Default Re: Cometic head gasket is junk!!!! (kstmotorworks)
Drilling out the rivets is not a problem, I have actually drilled out the rivets on a standard 0.030" Cometic to add a fourth layer--0.010" from another used Cometic to give me 0.040" instead of waiting and spending the money on a new 0.040 Cometic--worked fine. I do agree though that it kind of seems lousy on their part (cometic) that you would HAVE to remove the rivets just so it would clear.....I always use OEM now if possible--provided bore size and gasket thickness is OK.
erikwithak
Jul 17, 2009 01:15 PM
project ak
Jul 29, 2006 12:04 PM
mattduskater
Oct 5, 2003 03:01 AM
tilt
Nov 29, 2002 02:01 PM
S13 slide
Jan 4, 2002 06:20 PM
