Are 96-00 civic distributors all swapable???
I'm talking about the sohc motor dizzy's. Looking into buying someones dizzy that came out of their 98 civic and put it into my 99 civic. They look the same but when I checked with my local Honda dealership, the part #'s were different.
So will it work??
Thanks
So will it work??
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Frames are the same but the internals are not. </TD></TR></TABLE>
hmm, I don't know if this helps but this weekend I took a SOHC (96') Coil and used it to
replace me 2000 CTR Coil, same ****
Is this fact or opinion?
If it's fact then it is NOT swapable, right.
Thanks for the input.
Did that last year. Took the plug from my 99 and repinned the 98 dizzy. You will have 1 extra wire that isn't needed. The diagram you need is on here somewhere
by internals i meant the sensors and plugs. Ignition Coils and Ignitors are interchangable throughout 92-00 civics and integras.
Between obd's is NOT direct bolt on.
distortedfuture
38
Jan 22, 2004 05:08 PM
