stock ek radio
Old Oct 23, 2006 | 12:24 AM
2DoorBandit's Avatar
Default stock ek radio
tommorow i will be putting an aftermaket headunit in my friends 97 civic hatch and was wondering how do i remove to factory headunit
thanks in advance
Old Oct 23, 2006 | 02:48 AM
jdmOPTION2's Avatar
well the way that i did it was, i stuck my hand behind the radio and poped it out. there should be an opening right next to the gas pedel, if you got little hands then stick it up there and pop it out. you should put the new head unit on the bottom near the cup holder, so when your parked you can lift up the cup cover and hide you head unit, then for the big gap that your old head unit left get a block off plate
Old Oct 23, 2006 | 04:05 AM
MikeD718's Avatar
Default Re: (jdmOPTION2)
if hte oem radio hasnt been removed before you will have to get behind it and remove the bolt holding it to the car.
Old Oct 23, 2006 | 04:33 AM
Eran's Avatar
HT White Ops
Here's the steps:
1. Remove driver-side bolster pannel (the big plastic piece that holds your switches and fuse pannel).
2. By pressing in the sides, drop your glovebox.
3. Remove the center bolster pannel (the one that holds your 12v socket).
4. With a stubby philips-head screwdriver, look up behind where the center bolster was and unscrew two silver screws (they look like computer case screws).
5. Push radio out.
6. Remove all plugs (din, antenna, harness, security).
Vioalah.
Old Oct 23, 2006 | 05:23 AM
pdiggitydogg's Avatar
http://www.installdr.com/Insta...3.pdf
hondaPINK
Audio / Security / Video
Oct 29, 2006 08:27 AM
SUPER_JESUS
Jul 12, 2006 05:12 PM
93allmotorcoupe
Mar 17, 2006 08:43 AM
texasnick
Jan 25, 2005 11:06 PM
bennihana
Jan 20, 2004 10:54 AM
