front sway bar questions??
can you you please help me decide on a front sway bay for my eg? i already have a 22mm sway with the asr brace. what size front would you recomend? thanks for your input!
Modified by 95 hatch at 3:44 AM 10/23/2006
Handles pretty well. I need to get new struts though. You'll need 94-01 Integra front lower control arms, front sway bar, sway bar bushings, and d-brackets. Depending on the front sway bar, you'll need either the L-shaped or I-shaped endlinks.
I alreadsy have the control arms with the sway bar hole in them, can i just go to a dealer and get the, sway bar ,bushings and d brackets??
Yes, you'll need:
51300-ST7-003 SPRING, FR. (24MM) [QTY: 1]
51306-ST7-000 BUSH (24MM) [QTY: 2]
51308-SR3-000 HOLDER, R. FR. [QTY: 2]
94050-08080 NUT, FLANGE (8MM) [QTY: 2]
95701-08016-08 BOLT, FLANGE (8X16) [QTY: 2]
51320-ST7-003 LINK, FR. STABILIZER [QTY: 2]
51312-SR3-000 RUBBER [QTY: 4]
90212-SA5-003 NUT (10MM) [QTY: 2]
90362-SF1-003 NUT, SELF-LOCK (8MM) [QTY: 2]
i wouldnt go with anything aftermarket. its probably too big. and you can get a lesser sized front swaybar from the junkyard off another car.
which car? i dunno. i dont know EG's and interchangeability, other htna looking itno whats available for DC's.
and you havent mentioned what springs youre using.
so i should look in the bone yard for a sway bar, or just go to the dealer and get a new one? 8k rear 10k front. do you think 24mm is to big?
i dont see a problem with a junkyard swaybar if it has no indication of damage.
honestly, i dont know about EG's. i certainly wouldnt put a 24mm front swaybar on my crx. but its bent differently. so it may not be comparable. and it may be hollow. i dont think any typical aftermarket swaybars are hollow.
you have to just try it out and see if you like it better. jumping to whats the biggest step, like probably a solid aftermarket bar, would not be the best step to take, since its probably the most expensive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">huh, i would suggest the opposite.
first D bracket and bushing. then endlinks.
whatever works.</TD></TR></TABLE>
I mounted the endlink first to the LCA, then the d-bracket. Much easier for me.
do you have to take the cat off first, cant seem to get the bar close to mount the d-brackets?looks like the only way?? cant find my helm for a diagram!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 hatch »</TD></TR><TR><TD CLASS="quote">do you have to take the cat off first, cant seem to get the bar close to mount the d-brackets?looks like the only way?? cant find my helm for a diagram!!</TD></TR></TABLE>
I unbolted the exhaust from the header and I unbolted the shift linkage/stabilizer. Then I squeezed the bar through. Is your bar facing the correct way?
