Trying to replace the valve seals on my D15B7
Old Oct 22, 2006 | 08:35 PM
averyvm's Avatar
Default Trying to replace the valve seals on my D15B7
There is this tool that my grand pa was telling be about that threads into the spark plug hole and allows you hookup a compressed air hose to it. this in return pushes on the valves and prevents them from falling down into the combustion chamber.
Has anyone heard of this tool and do they know where i could get one?
If you havent heard about this do you know any way of changing the valve seals without taking off cylander head
thanks
Old Oct 23, 2006 | 03:16 AM
averyvm's Avatar
Default Re: Trying to replace the valve seals on my D15B7 (averyvm)
still need help ttt
Old Oct 23, 2006 | 03:25 AM
RC000E's Avatar
You can use a leakdown tester, or even a compression tester hose that has an air fitting on the other end. The easier method though, is to pull your spark plug and weave some nylon chord down in the combustion chamber, then turn that cylinder to top dead center. The chord will push on the valves and keep them from falling.
Just use a compressor to remove your valve springs, then change out the seals.....then reassemble.
Old Oct 23, 2006 | 06:13 AM
bluedlude's Avatar
Default Re: Trying to replace the valve seals on my D15B7 (RC000E)
yeah, the hose from a compression tester would be ideal. you are going to need something to remove and reinstall the valve keepers also, if you havent thought of that already.
just out of curiosity, why do you need to change the stem seals? if they are leaking, the your guides are probably out of tolerance. pick up a snap guage and micrometer or a decent caliper and check the stem to guide clearances.
Old Oct 23, 2006 | 06:20 AM
averyvm's Avatar
if i were to buy the compression tester are you sure that i would be able to hook up the air hose to it
Im think im leaning towards the second method since it invovles less money. Im just scared that the valves may still fall down.
Old Oct 23, 2006 | 06:23 AM
averyvm's Avatar
the rate at which the oil is leaking tells me that the valve stem seals are done. if it was a clearence issue i dont think oil would be leaking as fast.
Old Nov 28, 2006 | 01:49 PM
EJ1 wilcox's Avatar
Default Re: (averyvm)
Did you ever end up doing this? How did it go?
I need to replace my valve seals soon and want to do it with the head still on there as well.
Old Nov 30, 2006 | 07:59 AM
em1si's Avatar
curious as well...if u havent and still are...please take pics for a write up...definetly good topic if possible
Old Apr 7, 2008 | 06:57 PM
Metal Head's Avatar
Default Re: (em1si)
Back from the dead, Do you have to mess with the valve lash afterwards?
I woudl think Autozone would sell/Lend that part your talking about. I have to do my valve seals as well, Anyone know if all D series seals are the same ? Ive got a D15B Vtec and aquired some Del sol D16Z6 Viton seals for free new.
blaxican_707
May 13, 2016 06:11 AM
MIsterE533
10
Sep 14, 2010 07:18 PM
averyvm
Oct 23, 2006 05:35 PM
Witty
Mar 26, 2004 10:48 AM
