obd1 conversion help
Old Oct 22, 2006 | 07:44 PM
90b16CRXhf's Avatar
Default obd1 conversion help
Well i have a obd0 b16a n i wanted to convert it to obd1 i have the conversion harness, dizzy n 02 sensor n i was wanted to kno if i needed to change the injectors n how do i do this i m fairly new to this conversion n my friends are like bricks when helping me with this so im askin u guys...
Old Oct 24, 2006 | 10:01 AM
90b16CRXhf's Avatar
Default Re: obd1 conversion help (90b16CRXhf)
help?
Old Oct 24, 2006 | 10:34 AM
APEX CRX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90b16CRXhf &raquo;</TD></TR><TR><TD CLASS="quote">help? </TD></TR></TABLE>
look up the info on http://www.rywire.com
Old Oct 24, 2006 | 11:15 AM
NikoZai's Avatar
Default Re: obd1 conversion help (APEX CRX)
Yup, the OBD0 to OBD1 ECU Jumper instruction has nice lil pictures that tell you how.
http://rywire.com/store/faqdes...id=22
Old Oct 24, 2006 | 11:27 AM
Ch3mik's Avatar
Default Re: obd1 conversion help (NikoZai)
you only need the :
obd1 vtec ecu
obd1 or obd2 vtec distributor if
obd1-obd0 ecu rywire harnes
rywire dist jumper if you go with an obd1 dist
4 wire 02 sensor
injectors stay the same.
Old Oct 24, 2006 | 12:50 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: obd1 conversion help (Ch3mik)
keep the injectors if you keep the resistor box, you can just rewire the distributor to save some money
Old Oct 24, 2006 | 06:55 PM
90b16CRXhf's Avatar
Default Re: obd1 conversion help (HondaPartsHero)
k thanks thats what i figured but wasnt sure i have the rywire conversion harness n the harnesses that the obd0 to obd1 dizzy adapter 2 so it should be easy.but i wasnt sure if i had to change the injectors neway when i tune the car after i build the head
Old Oct 24, 2006 | 06:57 PM
90b16CRXhf's Avatar
didnt kno if it was easier to change them now or later
KDvtec5757
Jul 8, 2008 07:58 PM
MniMeHatch89
May 24, 2007 09:10 PM
teggytegteg
Apr 16, 2006 12:11 AM
Ls On StErIoDs
Sep 12, 2005 09:04 PM
civic efb16
Nov 22, 2004 06:46 AM
