chipped ecus
Old Oct 22, 2006 | 05:28 PM
kantfadedisazn's Avatar
Default chipped ecus
i'm looking into buying a chipped p30 ecu with the mugen program from http://www.ff-squad.com/ecu/ecu.obd1.dohc.vtec.htm
for my jdm b16a and i was wondering if the claims made for these things are real or are they just going to hurt my motor (no speed limiter redline set to 8500 advance air/fuel ratio) should i look into it or leave it alone
u guys think that would work with my set up that i will be building its kinda a lowbudgt performance daily driver
B16a from HMO(Roughly 52,XXX)
*Denso Iridium spark plugs
*NGK Spark plug wires
*Hasport Mounts
* exedy carbon clutch
*skunk2 type 2 cams
*toda cam gears
*ugr titanium vavle springs and retainers
*DH- racing 75/69mm throttlebody
*DH racing ported typhoon intake manifold/ same as AEBS but better
*Intake
*B&M no bend short shifter
*Energy shifter bushings
*New intake manifold gasket
*JKOBD conversion(Car is OBD1)
*Battery relocated to the back with SCCA approved battery box
*DC sports 4-2-1 Header
*Omnipower test pipe
*Greddy SP 2 Exhaust
Modified by kantfadedisazn at 6:47 PM 10/22/2006
Old Oct 22, 2006 | 05:48 PM
Default Re: chipped ecus (kantfadedisazn)
help please
Old Oct 22, 2006 | 05:51 PM
98vtec's Avatar
moderator emeritus
chips suck
true story.
get it tuned.
Old Oct 22, 2006 | 06:00 PM
Default Re: chipped ecus (98vtec)
even if its from a reputable company?
Old Oct 22, 2006 | 06:04 PM
98vtec's Avatar
moderator emeritus
all engines are different. Theres no such thing as a tuned chip without actually tuning the car first hand.
i've never understood why people go to OBDI ecu's if they arent going to get the engine tuned.
Old Oct 22, 2006 | 08:05 PM
mtber's Avatar
I agree, that tuning is the key, but a chipped ecu with a basemap specifically for your setup is the next best thing
ShawnbobHatch
Jan 15, 2010 07:04 AM
kantfadedisazn
Nov 13, 2006 08:52 PM
kantfadedisazn
Sep 27, 2006 06:52 PM
M15
Aug 17, 2006 01:17 PM
Jiggles
Jul 13, 2005 10:02 AM
