need help on b16a mods
Old 01-15-2010, 06:18 AM
ShawnbobHatch's Avatar
Default need help on b16a mods
heres what i have done so far:
JDM B16
type r cams
stage 2 clutch
ECU
P28 chipped tuned
datalogging
Ignition
Magnacore ignition wires
NGK spark plugs
Mallory hy fire ignition system
Nology ignition coil
Intake
AEBS intake manifold
LS throttle body
Short ram intake w/ filter
Exhaust
Dc sports header
OBX cat back
what else could i do for relatively cheap and be able to see a decent change? my first to second is good but once i hit third it just kinda feels like boggggggggggg. i guess money wise im lookin to spend 350-400 for now
Old 01-15-2010, 06:35 AM
vtechjunkie's Avatar
Default Re: need help on b16a mods
Was the tuner any good at tuning? It sounds odd that it bogs in third. Address that situation first. Once that is figured out, then get a set of Vitara pistons in there and up the compression. I would also switch out that short ram for a cold air. Other than that, you are starting to get into the expensive parts for speed. Short of ITB's, your going to have to reduce the weight to make it faster.
Old 01-15-2010, 06:42 AM
i just told the guy what mods i had then he tuned the chip then sent it to me for 35$. cant beat that lol, it dosnt exactly bog it just feels slow. ill try the intake, whats the best brand?
Old 01-15-2010, 06:49 AM
ricanzxrebel's Avatar
u can do nitrous, a bigger throtle body. and a tri y header
Old 01-15-2010, 06:54 AM
migrod1's Avatar
get an AEM cold air intake with a bypass valve so you don't have to worry about sucking up water especially if your in a state where it rains a lot
Old 01-15-2010, 07:01 AM
DMC'sCRX's Avatar
A new intake manifold will give you a little extra power. I've always preferred a skunk2 intake mani myself.
Old 01-15-2010, 07:04 AM
dpetro1's Avatar
Originally Posted by ShawnbobHatch
i just told the guy what mods i had then he tuned the chip then sent it to me for 35$. cant beat that lol?
this is not considered a tune. unless your car was on the dyno with the tuner making changes based on your actual afr and timing values then you might as well just run the stock map. do you have a wideband? if so what are your afr's?
generally for N/A you need big cams and high compression to make power.
99skunk2
10-02-2012 01:48 PM
ShawnbobHatch
Mid-Atlantic (Sales)
03-09-2010 06:30 PM
ShawnbobHatch
03-01-2010 08:38 PM
ShawnbobHatch
11-25-2008 11:46 AM
ShawnbobHatch
18
11-12-2008 06:43 AM
Quick Reply: need help on b16a mods
