clicking sound while braking
Old Oct 22, 2006 | 04:56 PM
marks97el's Avatar
Default clicking sound while braking
I just replaced my inner and outer tie rod ends. I took it for a litle spin right after i did it to see if everything worked fine. Other than an ovbious alignment needed the car seemed fine. However, after a while a rythmic clicking sound was heard while braking at low speeds. The slower the car was moving, the slower the clicking sound. When i release the brake no sound is made.
The performance of the breaking is the same as before, except for this concerning sound.
Does anyone have any input on this. And if you tell me i messed up while doing my tie rod ends and now need to spend thousans o dollars to fix it i will MURDER YOU!!!
Old Oct 22, 2006 | 05:21 PM
crawlin's Avatar
Default Re: clicking sound while braking (marks97el)
are you sure its just under braking and not around corners and such?
if your driving a honda it will not cost thousands of dollars barely hundreds
Old Oct 24, 2006 | 05:37 PM
nsxtasy's Avatar
H-T Order of Merit
Default Re: clicking sound while braking (crawlin)
A clicking sound is not uncommon when using aftermarket brake pads. It's usually caused by brake pads that are ever so slightly different in size or shape from the stock pads, so they shift slightly inside the calipers when the brakes are applied. If so, it's nothing to worry about.
Oh, and BTW, this is the "Wheel and Tire" forum, not the Brake forum. Ask in your model forum (Integra forum, Civic forum, etc) for questions about brakes.
Old Oct 24, 2006 | 06:14 PM
shutta's Avatar
make sure everything with yrou brakes is torqued down good.
dr.vroom
Suspension & Brakes
May 24, 2014 09:05 AM
pizzamanprelude
Jul 16, 2006 02:16 PM
extracrunchie
Jul 4, 2005 08:38 PM
EJ1 wilcox
Aug 15, 2004 03:57 PM
vietboixstunnah
May 10, 2003 01:00 PM
