Will an OBD1 work with pgmfi
Old Oct 22, 2006 | 04:52 PM
crxowner's Avatar
Default Will an OBD1 work with pgmfi
My freind has a crx dx(pgmfi) and wanted to know if he could use an obd1 gsr wiring harness for his GSR swap, obviously he would use an obd1 ecu
im pretty sure it wont work but i just want to get a second opinion
Old Oct 22, 2006 | 04:59 PM
Boosted Chemist's Avatar
Default Re: Will an OBD1 work with pgmfi (crxowner)
use the dx harness, add the injectors and **** from the gsr, and use the vtec **** to make a subharness.
and see rywire for a conversion harness
Old Oct 23, 2006 | 03:39 PM
crxowner's Avatar
so... is that a yes or a no?
Old Oct 23, 2006 | 03:56 PM
89 civic si's Avatar
Default Re: (crxowner)
you have to use your original wiring harness then take the plugs off the dizzy and the vtec crap you cannot use the gsr harness
Old Oct 23, 2006 | 06:06 PM
HondaPartsHero's Avatar
Technical Hero
Default Re: (89 civic si)
did he convert to PGMFI? If not the DX is DPFI and he will have to convert to PGMFI. Then you can either make a subharness out of the GSR harness for the VTEC pressure switch, VTEC solenoid, Knock sensor, and IAB or buy one. But no you can not use the GSR harness without a whole lot of wiring
Old Oct 24, 2006 | 11:35 AM
crxowner's Avatar
Thanks guys what about the crx SI harness
He's not good with wiring and neither am I so we're trying to take an easy way out
Old Oct 24, 2006 | 12:35 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxowner &raquo;</TD></TR><TR><TD CLASS="quote">Thanks guys what about the crx SI harness
He's not good with wiring and neither am I so we're trying to take an easy way out</TD></TR></TABLE>
wont work, u need to use your dx with all the extra **** added. trust me thsi is the easiest way. I can wire it for you if your in western ny
Old Oct 24, 2006 | 05:51 PM
crxowner's Avatar
Well thats not going to work cuz we're in tampa I'll just have to learn how to wire a car up thanks guys
90Rexx
Sep 15, 2010 10:47 AM
jordy75
Jun 10, 2010 01:59 PM
B18CYAAA
Jul 16, 2007 03:59 PM
agy2k2
Aug 6, 2006 05:10 PM
egturbo
Jan 11, 2004 09:45 PM
