Question about '90 DA..
Old Oct 22, 2006 | 04:32 PM
Custom Rex's Avatar
Default Question about '90 DA..
Does anybody know where the PA sensor(ABSOLUTE PRESSURE) is on my '90 integra RS cant seen to find a location for obd0 da's. I know in obd1 its inside the ecu... any help would be great i got this stupid code 13 constant.
Old Oct 22, 2006 | 06:56 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: Question about '90 DA.. (Custom Rex)
are you referring to the Manifold Absolute Pressure (MAP) sensor?
Old Oct 23, 2006 | 02:40 PM
Custom Rex's Avatar
Default Re: Question about '90 DA.. (GRAF-FITI)
well what is a code 13 on a 90 integra rs obd 0?
Old Oct 23, 2006 | 03:03 PM
tegG2's Avatar
Atmosphere Pressure sensor, and I am not sure where it is but If you have a 92-93 ecu on your 1990 that can make it through a code 13 because of it having an internal PA like you said.
http://g2ic.com/tegtips/engine/13.html
Old Oct 23, 2006 | 03:08 PM
Custom Rex's Avatar
Default Re: Question about '90 DA.. (tegG2)
lol. see i cant find this **** anywhere no manual, no search topic. nothing. people only refer to the obd 1 pa sensor which is in the ecu. but obd 0 is suposed to be external???
Old Oct 25, 2006 | 01:50 PM
Custom Rex's Avatar
for the record...
90 and erlyer have the PA externally by the passenger kickpanel.
according to mitchell ondemand 91-93 have it internally inside the ecu.
even tho 91 da is still obd 0
thanks guys for all the help, hope this can help somone else..
use the pa sensor testing procedure to check your wires in a 90 and erlyer. for 91-93 reset ecu than try again if problem re-occurs change ecu with known good one, and try again.
as for automatic cars 91-93 u will also need the check the AT control unit casue the pa sensor is wired up with it!
90goldhatch
Apr 3, 2010 12:47 PM
crampinyourstyle
Aug 7, 2006 02:59 PM
nexus da9
Mar 19, 2004 07:45 PM
