High rpm at 50mph
Old Oct 22, 2006 | 04:03 PM
frankhky's Avatar
Default High rpm at 50mph
The speedometer gauge on my 1995 Honda Accord quit working so I bought a used gauge cluster and had it installed. Now the rpm is to high for example at 50 mph it indicated 3500 rpm. I believe the tach is showing the accurate rpm.
I did notice after installing the gauge cluster that it was missing the abs indicator. The check engine light is off and all indicators and gauges seem to be working.
Could anyone help on why the engine is running at a high rpm?
Thanks
Old Oct 22, 2006 | 05:16 PM
02 accord's Avatar
Default Re: High rpm at 50mph (frankhky)
Does the engine sound like it's running at 3.5k? Or are you just guessing that the tach is accurate?
Old Oct 22, 2006 | 05:53 PM
frankhky's Avatar
Yes, it does sound like it's running at 3.5k.
Old Oct 22, 2006 | 06:11 PM
TheMuffinMan's Avatar
He knows where you live!
You're not running it in D3 are you?
Old Oct 22, 2006 | 06:14 PM
frankhky's Avatar
No, I know it sounds like it but I'm not.
Old Oct 22, 2006 | 07:31 PM
02 accord's Avatar
Default Re: (frankhky)
Put the original cluster back in and see what happens.
Old Oct 23, 2006 | 06:18 PM
frankhky's Avatar
I'll give that a try but it will be a few days before I will be able to.
Thanks
Old Oct 24, 2006 | 02:30 AM
YeuEmMaiMai's Avatar
did the cluster come out of an accord with the SAME type of engine as your car? IF you have a I4 then you need a cluster calibrated for an I4. Same for a V6.......if you install one into the other, your tach will be fudged up.......
antihero12
Classic Hondas
Feb 17, 2013 07:37 PM
j3dimindtr1cks
Honda Civic (2001 - 2005)
Sep 21, 2006 08:18 AM
hondahustle
12
Jun 15, 2006 01:09 AM
DA KING
Jun 27, 2004 02:19 PM
