driving vibration, what could it be?
on my 95 civic, i'm getting some light vibration from low speed, and noticeable vibration during 65-80 speed range. tires ARE NEW and wheels are fully balanced, and i was told it could be either my axles or inner joint?
all the boots looks fine, no rip or tear. i'm not hearing any ticking sounds from some peopel suggested as axles going bad... any tips and suggestions are welcome, thanks
Modified by yoorang at 7:10 AM 10/28/2006
can be transaxle bearings, are you leaking tranny fluid.....my axle actually wobbled out once as a cause of the transaxle bearing giving at 90mph....if the car is in the air....can u wobble the tires, if so check your control and tie rod arms, if not it's you wheel/ hub bearing
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rocketfuelcerx »</TD></TR><TR><TD CLASS="quote">can be transaxle bearings, are you leaking tranny fluid.....my axle actually wobbled out once as a cause of the transaxle bearing giving at 90mph....if the car is in the air....can u wobble the tires, if so check your control and tie rod arms, if not it's you wheel/ hub bearing</TD></TR></TABLE>
yea, i got the car up in the air last week, and there is no play on the wheels at all. thx man!
it could also be tires, i went through 6 months of searching for the culprit of my vibrations and i replaced almost everything in my front end and come to find out that it was bad tires....they wer balanced and all the tires were just trash.
I have the same problem. I took my car to have the wheels balanced and the tech pointed out my bumpy tire. He said the culprit for the bumps was bad struts. So its possible you need new struts. I just got Tokiko illuminas so I'll be a test dummy. I'm no expert though.
Good luck!!
Good luck!!
my vote is with a flat spotted, or blistered tire.
the fact that you feel it at low speed, and at high speed means its a rotational issue, and right around 65-70 is the the right frequency for natural response at the wheels.
When driving around 70mph, see if the vibration changes or goes away when you close the throttle, vs. when you're on the gas. If it goes away, it's an inner CV joint. Those do not click when they go bad (as the outer joints do), they make a really nasty vibration under load.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 »</TD></TR><TR><TD CLASS="quote">When driving around 70mph, see if the vibration changes or goes away when you close the throttle, vs. when you're on the gas. If it goes away, it's an inner CV joint. Those do not click when they go bad (as the outer joints do), they make a really nasty vibration under load.</TD></TR></TABLE>
yes they do!
yes they do!
i think that was the problem, will find out in a few weeks. thanks so much!
94civiccupew/b7
23
Dec 11, 2009 06:27 AM
Acurazor
Suspension & Brakes
Jun 26, 2009 08:47 AM
Skip01
20
Jan 21, 2007 05:09 PM
