Help Misifre Cylinder 2 and 4
Car obd1 95 integra GSR, tubocharged b16a. , turboed chipped po6 AEM fuel rail, aeromotive FPR (running at 45lbs at idle), shows about 55lbs at 3k RPM load. 3in. open downpipe,
<U>Problem:</U>
Car runs rough, misfire on cylinder 2 and 4.
Car sat for a a year or so. Drained the whole tank and refiled it. Car has fuel and spark it runs real rough though. Replaced distributor with a new oem honda one. O2 sensor is new, injectors read the low 3ohm they should. Replaced the resistor box with a working one. Wiring of it is correct.
All crank, cyl, and TDC sensors read correct OHM value at ECU and dist.
Any ideas on the misfire. When i remove plugs in cylinder 2 and 4, no RPM changes are observed. Plugs are fuel soaked. Replaced plugs.
Any ideas would be greatly appreciated.
<U>Problem:</U>
Wisdom Teeth
Mar 25, 2013 10:26 AM
asianspeed
Mar 5, 2003 08:58 PM
