did swap no vtec
Old Oct 22, 2006 | 02:34 PM
j spec's Avatar
Default did swap no vtec
no vtec after doing b16 swap. i have checked the vtec solnoid and connections at/to ecu. computer throws a constant 21 as soon as you start the car. any ideas?
Old Oct 22, 2006 | 02:43 PM
NikoZai's Avatar
Default Re: did swap no vtec (roma's GSReg6)
Where did you pin it in at the ECU?
Use a volt-meter to check continuity from A8 to the solenoid
http://rywire.com/store/faqdes...46d72
Old Oct 22, 2006 | 03:16 PM
philkehn's Avatar
the pressure, solnoid, knock sensor and 2nd o2 sensors have to be wired in for a b16 swap.. Like he said just check your a8 pin... im not even sure if my vtec works i think its just really quite?? How are you sure it doesnt work?
Old Oct 23, 2006 | 06:05 AM
j spec's Avatar
Default Re: (philkehn)
yeah i made a sub harness and wired in the second o2, knock, vtec oil press, and solenoid. i also have checked continuity to all of these from sensor to ecu and double checked for correct pin location. What i don't understand is why it throws 21 as soon as car is started unless it is different from obd1 cars in which from my experiences 21 is only thrown after car reaches vtec engagement rpm.
Old Oct 23, 2006 | 07:11 AM
crxnj's Avatar
Default Re: (roma's GSReg6)
did you try re-setting the ecu yet?
Old Oct 23, 2006 | 09:39 AM
j spec's Avatar
Default Re: (Mr.speaker)
yep
Old Oct 23, 2006 | 01:01 PM
NikoZai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roma’s GSReg6 &raquo;</TD></TR><TR><TD CLASS="quote"> unless it is different from obd1 cars in which from my experiences 21 is only thrown after car reaches vtec engagement rpm.</TD></TR></TABLE>
My experience too. Really odd. If the wire checks out, and the solenoid is good (12v+ test) then replace the ECU.
Old Oct 23, 2006 | 07:36 PM
j spec's Avatar
Default Re: (NikoZai)
I'll try another ecu but i doubt thats it.
fstdsm
Jul 17, 2007 03:38 PM
ExclusiveCRX
11
Feb 27, 2007 06:17 AM
hahagasdcrx
Jun 28, 2004 07:16 PM
r7
12
Jun 13, 2002 10:21 AM
