Surging Idle
Old Oct 22, 2006 | 01:51 PM
Mr. LS VTEC's Avatar
Default Surging Idle
OK, now I'm running a turbo LS/Vtec and i've got surging in my idle. It will surge at any RPM for 500 RPM. Example, at idle it will surge from 1000 to 500, if I hold the throttle at 3000 then it will surge between 2500 and 3000. I've been messing with the idle control screw and cannot get it to stop. When I unplug the IACV it dies right away. I've cleaned the IACV and still no good. Is there an electrical test that can be done on the IACV to make sure that it is operational? Also, about how many turns from fully in should the set screw be? Also assuming that a vacume leak could be causing this, but I cannot find a leak anywhere. This is how I have my vacume lines setup, OBX Intake manifold so two acc. vacume lines. BOV and Wastegate going to same port on intake, FPR and GM 3 Bar on same Intake port. Also, I am running an Apexi Power FC.
Old Oct 22, 2006 | 02:05 PM
Heylookits shawn's Avatar
Default Re: Surging Idle (Mr. LS VTEC)
sounds like you have a vaccum leak somewhere. find that and you will fix the surge
Old Oct 22, 2006 | 02:21 PM
Default Re: Surging Idle (Heylookits shawn)
But is the car supposed to die when the IACV is unpluged?
Old Oct 22, 2006 | 03:43 PM
Man this sucks, theres not that much to the vacuum on this car. all of my connections are good, the manifold is tight, i just bled the coolant. WTF!!
Old Oct 22, 2006 | 08:58 PM
bump for a poor tired guy.
midnightluder
Jul 10, 2012 07:54 PM
wilrock
Apr 4, 2006 05:56 PM
egCoupe
10
Aug 12, 2005 12:54 PM
virusiidx
Jan 18, 2005 07:21 AM
steve_s
Jan 22, 2003 02:06 AM
