i have engine codes help
Old Oct 22, 2006 | 01:11 PM
v8 integra's Avatar
Default i have engine codes help
ok i just did a engine swap on my 96 civic ex i put in a a obd1 b16 p30 ecu
i jumped the ecu and i got i think 4 codes the first one is 3 fast flashes witch i would think its 3 MAP - manifold absolute pressure sensor, the secound is 2 long flashes and seven quick ones but theirs no 27 on the trouble shoot guide on the form here so im guess its 17 VSS - speed sensor, then the third code is two long ones witch would make it 20 Electrical load detector and my last one witch i got 4 long flashes and one quick one wtich makes that 41 Primary oxygen sensor heater. i have no idea how to fix any of these codes any help would be great!!! and i put in a new primary and secoundary o2 sensors so i dont know any help would be great.
Modified by v8 integra at 2:35 PM 10/22/2006
Old Oct 22, 2006 | 05:59 PM
v8 integra's Avatar
Default Re: i have engine codes help (v8 integra)
plz anyone?
Old Oct 22, 2006 | 08:43 PM
nighttrain33's Avatar
First off, make sure that the o2 sensor is wired in correctly. I.E. when I replaced my oil pump, when I took off the exhaust mani, the secondary o2 sensor pulled out when my mani accidently dropped on the ground. I pulled a code until I got all of the wires in the correct spot.
For the #3 code, you probably have to replace the MAP sensor.
You can find info about the code 20 here.
Lastly, make sure that the code 17 is indeed a code 17. If so, replace the VSS.
-Shane
Old Oct 24, 2006 | 06:07 PM
v8 integra's Avatar
thanks...i 4 got to include..i bought the wrong gauge cluter..i got one without the rpm gauge. and the speedo and milage doesnt work on it..could that be the problem? and also..how do i test the altenator if it is working properly..and my friend says i probably have a missing ground wires. how many and where should the ground wires be exactly? i think i have 3
Old Oct 24, 2006 | 07:02 PM
sql_civic's Avatar
Default Re: (v8 integra)
I had all kinds of whacky codes and such when I replaced my engine harness on a D16Y7/Y8 mini-me and it was a ground wire. If your B16 might be similar but check your grounds! On the D16 there's 1 from the block to the front of the chassis, transmission to body, and wiring harness to thermostat housing. The last one was the one that caused my problems.
Good Luck.
Old Oct 24, 2006 | 07:04 PM
Sleepy_Red_hatch's Avatar
Default Re: (sql_civic)
your code "27" is probably code 10 and code 17
EKdriverin703
May 5, 2011 07:21 AM
skaternak
Jul 20, 2008 10:50 AM
EvoEnvy
Jan 23, 2008 04:32 PM
Ehron
May 5, 2006 06:20 PM
crxtreme27
Sep 19, 2002 02:01 PM
