messed up the wiring harness...
after installing an aftermarket head unit, i decided to go back with the factory tape player. when i found the old wiring harness, i had cut the wires really close to the harness. how would i extend these wires? is there some way to put longer wires back into the small holes, or does some store have info on this?
get some wiring from a radio shack or what not and piggy tail them with some spade connectors.. this will make it easier to work with instead of getting ur nails dirty trying to connect 2 mm wires lol
thanks
you can just extend and crimp the wiring buy using longer wire and crimping them to make a longer connection... whenever I do installs.. i buy a plug in harness and leave the stock connector/wiring stock...
