Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Tire size
Old Oct 22, 2006 | 11:26 AM
0oE's Avatar
0oE
Default Tire size
I just got my new 07 civic LX coupe and also ordered the 17" HFP rims. What size tires would you recommend for these ? I dont plan on lowering it either.....yet
Modified by 0oE at 3:33 PM 10/22/2006
Old Oct 22, 2006 | 03:02 PM
mInI m3 Hondeezy's Avatar
Oem size 215 45 r17 or if u want low pro's go with 35
Old Oct 22, 2006 | 06:35 PM
Jay2005's Avatar
Default Re: (mInI m3)
what if you got 18" rims what would be the tire size?
Can someone explain the numbers in order to show how changing the rim size does not change how big the overall circumference of the wheel will be...does that make any sense? Basically when going up in rim size what numbers would change and why?
Old Oct 22, 2006 | 08:19 PM
now if u got 18's u would go with like 225 40 r18 or as low as 30. I kinda get what your saying jay try this see if will help http://www.discounttire.com/dtcs/infoTireMath.dos
Old Oct 23, 2006 | 06:49 AM
TRE_'s Avatar
Default Re: (Jay2005)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jay2005 &raquo;</TD></TR><TR><TD CLASS="quote">what if you got 18" rims what would be the tire size? </TD></TR></TABLE>
I'd say 215/40-18
Old Oct 23, 2006 | 04:50 PM
0oE's Avatar
0oE
Default Re: Tire size (0oE)
Hmm what about 225/40/17? Or will there be issues with rubbing while turning?
Old Oct 23, 2006 | 06:07 PM
Declectic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mInI m3 &raquo;</TD></TR><TR><TD CLASS="quote">Oem size 215 45 r17 or if u want low pro's go with 35</TD></TR></TABLE>
35 would look retarded... especially stock height
Old Oct 23, 2006 | 06:19 PM
Fa1's Avatar
Fa1
Ex. P205/55/R16
P - Passenger Vehicle
205 - width of tire in mm
55 - ratio of sidewall to tire width(multiply with tire width to get sidewall thickness in mm)
R - Radial Tire
16 - Size of rim the tire fits in inches
Old Oct 23, 2006 | 09:40 PM
Default Re: (SeanJohn1802)
yes maybe on oem ride height but once lowered man looks sexy got some 17's with 35 on mah eg lowered,
Old Oct 25, 2006 | 05:13 AM
R18A1FG's Avatar
i go with 225/45/17, sits pretty nice lowered just over an inch, only rubs if go flying over speed bumps or something
Old Oct 25, 2006 | 05:40 AM
blue rocket's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SeanJohn1802 &raquo;</TD></TR><TR><TD CLASS="quote">
35 would look retarded... especially stock height </TD></TR></TABLE>
not only would it look retarded it would throw off the speedo... people need to learn to keep the tires sizes consistent, 215/45/17.
Old Oct 25, 2006 | 05:46 AM
Type X's Avatar
Default Re: (blue rocket)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blue rocket &raquo;</TD></TR><TR><TD CLASS="quote">
not only would it look retarded it would throw off the speedo... people need to learn to keep the tires sizes consistent, 215/45/17.</TD></TR></TABLE>
damn right skipper
Old Oct 25, 2006 | 10:08 PM
0oE's Avatar
0oE
ok thanks for the input
Old Oct 25, 2006 | 11:57 PM
team3d's Avatar
17"--- 215/45/17
18"--- 225/40/18
19"--- 235/35/19
Old Oct 26, 2006 | 06:01 AM
kuanie's Avatar
Go with 225/45R17.. its closest to the stock 16" tyre profile.
Old Oct 26, 2006 | 06:07 AM
aznchzexr's Avatar
215/40/17 works well too
that's wut i'm running right now as i didn't want a huge sidewall
Old Jan 13, 2007 | 04:17 PM
0oE's Avatar
0oE
Default Re: (aznchzexr)
Well i dont want a huge sidewall but not paper thin either. Some of the roads out here are not the best. Also for lowering springs....eibach pros or sportlines. But ya 215/45 or 225/45 damn cant decide...lol. The 225 is gonna look lower profile...right or is the 215. I know width has something to do with that as long as the 45 series is the same
Old Jan 13, 2007 | 05:03 PM
RICO_'s Avatar
NO MERCY!
Default Re: (0oE)
225 will look lower profile i believe than the 215 with the same thickness.
Old Jan 13, 2007 | 07:00 PM
gus738's Avatar
Default Re: Tire size (team3d)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by team3d &raquo;</TD></TR><TR><TD CLASS="quote">17"--- 215/45/17
18"--- 225/40/18
19"--- 235/35/19</TD></TR></TABLE>
your right :D i have 225/40/18 lowerd and car doesnt seem to rub ....
19's are too much and 17's you see a big hole unless you drop it
Old Jan 13, 2007 | 07:05 PM
RICO_'s Avatar
NO MERCY!
Default Re: Tire size (gus738)
Yeah i wouldn't go with 19s. They would work but the tire will have to be a really low profile. Then you risk bendin the rim.
Old Jan 15, 2007 | 08:14 PM
0oE's Avatar
0oE
Default Re: Tire size (RICO_)
Thats what i figured 225 would look a little lower profile, what about springs........
Old Jan 16, 2007 | 03:01 AM
RICO_'s Avatar
NO MERCY!
Eibach, Comptech, or Tein S-techs. Those seem to be the most popular and the most reliable so far.
SunriseSunset
Honda Civic (2001 - 2005)
Feb 14, 2024 07:32 PM
walsh22
58
Mar 24, 2007 03:18 PM
latinf86
Sep 6, 2006 11:12 AM
FD3S
Oct 8, 2005 01:43 PM
1SLOWlsTEG
May 20, 2005 01:11 PM
