rear disk..
Old Oct 22, 2006 | 09:41 AM
MugenManR's Avatar
Default rear disk..
i got a rear disk conversion of a teggie. i wanted to know if i could jsut take the drum set up off my ek and jsut put the disk on instead of swtiching the hole arm and ish.
Old Oct 22, 2006 | 09:44 AM
ian.'s Avatar
Default Re: rear disk.. (MugenManR)
u mean "rear disc" and the answer is no the whole trailing arm and lines need to be replaced
Old Oct 22, 2006 | 10:09 AM
vsmferio96's Avatar
Default Re: rear disk.. (helloian.)
just got my swap off a 94 gsr and it's a lot easier to just replace the entire arm! Also just a suggestion but i'd recomend si ebrake cables instead of teg's because of length. other than that its bolt on cake man!
Old Oct 22, 2006 | 12:01 PM
clutch1515's Avatar
I did it in less than an hour
Old Oct 22, 2006 | 12:06 PM
EL Vap133's Avatar
I'd do the whole thing, I think it's easier.
Old Oct 22, 2006 | 07:10 PM
MugenManR's Avatar
Default Re: rear disk.. (EL Vap133)
thanks guys im doing this on my own, now for the brake lines, i got earls, but how do i go about hookin em up.
Old Oct 22, 2006 | 07:17 PM
nek9's Avatar
I recently got mines also and iterested on how the cable hooks up.. pics would realy help.
Old Oct 22, 2006 | 07:21 PM
MikeD718's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenManR &raquo;</TD></TR><TR><TD CLASS="quote">thanks guys im doing this on my own, now for the brake lines, i got earls, but how do i go about hookin em up. </TD></TR></TABLE>
its pretty straight forward, just remove teh stock ones and replcae with new. be sure to bleed the brakes when youre done.
Old Oct 22, 2006 | 07:47 PM
clm's Avatar
clm
Remove the old ones, put the new ones on. There might be a shim that holds the line connection to a bracket. It's straightforward as said previously.
You can also swap the spindle out in the rear, which might be an ideal option if you think the donor trailing arms you bought are bent.
Old Oct 26, 2006 | 07:52 PM
MugenManR's Avatar
Default Re: rear disk.. (clm)
any one know were theres a write up on how to do this ish
Old Oct 26, 2006 | 08:24 PM
t0p_sh0tta's Avatar
What do you guys do to keep brake fluid from pouring all over the place once the caliper is off?
Old Oct 27, 2006 | 09:37 AM
EL Vap133's Avatar
Default Re: rear disk.. (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">What do you guys do to keep brake fluid from pouring all over the place once the caliper is off?
Use a plug of some kind. I use a small rubber hose and plug the other end of it.
Old Oct 27, 2006 | 10:19 AM
MugenManR's Avatar
are there any brake boosters or master cilinders i could use also?
Old Oct 27, 2006 | 10:20 AM
EL Vap133's Avatar
For an EK right? Just go with the 99-00 Si MC, the BB is the same so you don't need to replace it.
Old Oct 27, 2006 | 10:26 AM
MugenManR's Avatar
how much do you think that would cost?
Old Oct 27, 2006 | 10:29 AM
EL Vap133's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenManR &raquo;</TD></TR><TR><TD CLASS="quote">how much do you think that would cost? </TD></TR></TABLE>
What, the Si MC? Depends on if you want a new or used one and where you buy it.
socalrex88
Jul 17, 2007 03:08 AM
meric0786
Mar 14, 2007 09:15 AM
jdm94accord
May 4, 2006 09:21 AM
hair_rice
11
Jan 27, 2004 01:49 AM
EGsixer
Jan 14, 2003 01:55 AM
