ls IACV same as gsr ?
hi
my idle is expletive up now I need to replace my iacv i have a ls laying around and I was wondering if the ls will fit a gsr head with a blox intake manifold I allready match the bolts and it fits now my question is would the work the same ? , thanks
well I'am having idle problems , happen to me about 2 days ago I was on the highway on my way to home and when got off the highway to the first traffic light the engine was going crazy reving from 800 to 3000/2500 rpms? i though of the iacv replaced with a ls iacv and the dam thing still
this is what i just done
pull the intake and I put my finger in the trottle body lower port bypass and the engine idle was good steady at 800 rpm do u guys think is the fast idle thermo valve ? thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super-hatch »</TD></TR><TR><TD CLASS="quote">hi
i'm wondering the same thing.. i have a 98 gsr and was wondering if the ls/gsr iacvs from 94-95, or the 99-01 would work.. umm, anybody?
Basically there are 2 IACV designs.....for the 92-01 Integras anyway. The narrow bolt pattern and the long bolt pattern. Edit: Spreading misinformation is bad!!!
Sounds like it could be the FITV, take it off and inspect it.....also, if you unplug the IACV, what does it do? If you unplug the IACV it should idle around 650....maybe higher depending on your base idle. It also might stall out due to your base idle being set too low....but that should tell you if its the FITV or IACV.
Modified by 95 integra at 2:17 PM 11/3/2006
[QUOTE=95 integra]Basically there are 2 IACV designs.....for the 92-01 Integras anyway. The narrow bolt pattern and the long bolt pattern. LSs use the narrow pattern, GSRs use the long pattern...QUOTE]
how sure are u of this? mines a 98 gsr and i called acura. they said the 96-98 ls and gsr are the same..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eknorcal »</TD></TR><TR><TD CLASS="quote">[QUOTE=95 integra]Basically there are 2 IACV designs.....for the 92-01 Integras anyway. The narrow bolt pattern and the long bolt pattern. LSs use the narrow pattern, GSRs use the long pattern...QUOTE]
how sure are u of this? mines a 98 gsr and i called acura. they said the 96-98 ls and gsr are the same..</TD></TR></TABLE>
36450-P6T-S01
36450-P6T-S01
Looks like they/you are correct.....apparently I need to update my OBD II skills.
36450-P6T-S01
36450-P6T-S01
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">
36450-P6T-S01
36450-P6T-S01
Looks like they/you are correct.....apparently I need to update my OBD II skills.</TD></TR></TABLE>
do u think the older models 94-95, or new models 99-01 would fit onto my IM?
36450-P6T-S01
36450-P6T-S01
I dont know, I tried looking through my old pics but couldnt find any shots of the GSR IM. I have 6-7 LS manifolds outside and all of them have the short design (minus a pre 94 model)....and I thought my GSR had the long bolt pattern, but it looks like Im wrong because I know I put a 96+ intake manifold on my 95 model and the IACV bolted up just fine.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">I dont know, I tried looking through my old pics but couldnt find any shots of the GSR IM. I have 6-7 LS manifolds outside and all of them have the short design (minus a pre 94 model)....and I thought my GSR had the long bolt pattern, but it looks like Im wrong because I know I put a 96+ intake manifold on my 95 model and the IACV bolted up just fine.</TD></TR></TABLE>
well thanks though. a lot of people here dont know so ur the only one respondin
Race Egr
Apr 3, 2004 02:20 PM
