civic hatch engine harness question please help!
aslong as it came from a 92-95 civic. also its very probable that the 93-95 del sol , and 94-95 integra harness will plug in as well.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmyflys »</TD></TR><TR><TD CLASS="quote">any tips on how to wire the vtec the easiest if i have the d16 harness do i have to cut the wires from the vtec solenoid and wire them to the ecu?</TD></TR></TABLE>
I you have an ex or si wire harness from a 92-95 civic then your 4 wire o2 sensor and vtec are plug and play. The vtec is already pre-wired to your shock mount harness from the car.
You shouldn't have to cut anything or run new wires for anything as lond as you have a 92 civic. that is the only year they were pre-wired.
Hope that gives you a clear answer.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Timmyflys »</TD></TR><TR><TD CLASS="quote">so the rywire plugs into the vtec solenoid and then straight to the ecu </TD></TR></TABLE>
I think you have to add one wire to the cabin harness for the ecu pinout, but read the instructions on that page I linked. Other than that, it's completely plug + play, right on the shock tower.
skieza97
21
Nov 15, 2022 06:12 AM
MrEg
Sep 17, 2006 10:02 PM
