Car doesn't want to start... Help!
Old Oct 22, 2006 | 04:42 AM
JDM-Riders's Avatar
Default Car doesn't want to start... Help!
I have a LS swap 94 civic. My car will not turn over, it will crank but not turn over at all. I had a complete MSD setup on the car that I uninstall to find out what the problem was. I replace the distributor and still nothing. I checked for spark and there was no spark, even after I replace the distributor!!!
Another thing is that I don't think I am geting any gas either because I don't smell anything and most people said that if they don't get any spark they would smell gas not being burn... No gas no spark... Help! I will replace the ECU and fuse today... My fuel pump is less than a month old. Can it be faulty wires??? More fuses?
What can I do next??? All help and advices would be greatly appreciated...
Old Oct 22, 2006 | 05:05 AM
dowdle's Avatar
Default Re: Car doesn't want to start... Help! (hawj920)
check all your grounds. Sounds like what was going on with my car. but if you will wait till dark and have someone try to start the car while you check under the hood for a spark. Because electricity will take the shortest root and will spark where there is a loose ground.
si1992
Honda CR-V & Element
Apr 18, 2012 05:03 AM
platinum_rich
15
Feb 25, 2012 08:16 PM
j4yzn
Aug 24, 2009 12:45 PM
intgraCA
Jul 27, 2006 09:12 AM
