my head is making a clicking sound
Old Oct 22, 2006 | 04:30 AM
teamvirus's Avatar
My car breaks a lot!
Default my head is making a clicking sound
ya so just the other day my car started ticking, and it speeds up as i drive faster, im not sure what it could be, a friend of mine said it could be my valve lash, what do you guys think..and what should i do to fix my problem
Old Oct 22, 2006 | 06:06 AM
92ehatch's Avatar
Default Re: my head is making a clicking sound (teamvirus)
adjust the valves its not hard.
i just adjusted mine, it helped but i need to do it again. usually takes me about 3 to 4 tries to get em the way i want. (little to no tick)
it could also be the injectors.
one way to find out is star the motor, sit your *** on top of you valve cover and put your ear right next to the injectors and valve cover.
Heretic:Si's Avatar
you probably just need a valve adjustment.
Old Oct 22, 2006 | 06:12 AM
Syndacate's Avatar
Default Re: my head is making a clicking sound (Heretic:Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Heretic:Si &raquo;</TD></TR><TR><TD CLASS="quote">you probably just need a valve adjustment.</TD></TR></TABLE> @ both replies.
Sounds like a valve tick. No biggie, do a valve adjustment and you'll be fine.
(we hope).
If not you have a lot bigger problems
Old Oct 22, 2006 | 06:25 AM
92ehatch's Avatar
Default Re: my head is making a clicking sound (Syndacate)
we dont know what motor this is for but for 92-95 d series motors
intake .007-.009
exhaust .009-.011
rotate crank counter-clockwise until piston 1 is at TDC (up points up) set number 1 valve lash
rotate crank 180° (cam does 90°) and number 3 will the at TDC (up points to exhaust side) set number 3 valve lash
rotate crank 180° and number 4 will be at TDC (up points down) set number 4 lash
rotate crank 180° and number 2 will be at TDC (up points to intake side) set number 5 lash
from pages 6-69 thorugh 6-71 in the helms manual
Old Oct 22, 2006 | 10:38 AM
jdeemseerx's Avatar
Default Re: my head is making a clicking sound (92ehatch)
^^ he means 90 degrees NOT 180.. sorry but it is kinda confusing if youve never done it before
Old Oct 22, 2006 | 10:42 AM
DeltaCharlie2's Avatar
Default Re: my head is making a clicking sound (jdeemseerx)
Sounds like a ticking valve. Do the valve adjustment as previously recommended and see it that fixes it.
Old Oct 22, 2006 | 12:08 PM
teamvirus's Avatar
Default Re: my head is making a clicking sound (forthewin)
thanks so much for the info.
by the way the motor is a b16a2
and it might be the injectors cause im running a greddy turbo kit on stock injectors with a jackson fmu not the blue boxs
Old Oct 22, 2006 | 06:20 PM
teamvirus's Avatar
bump
Old Oct 22, 2006 | 06:54 PM
jdeemseerx's Avatar
what are you bumping for? let the car sit overnight and do a valve adjustment the next day. if the noise isnt there after everything is within spec then its not the injectors
Old Oct 22, 2006 | 07:30 PM
nighttrain33's Avatar
Valve clearance for a B16a2 is .06-.07 intake and .07-.08 exhaust.
-Shane
99gsrfasho
Dec 31, 2009 10:07 PM
DC5mike
Jun 27, 2008 06:38 PM
Nextelbuddy
22
Sep 21, 2004 03:06 PM
deconstruct
23
Jun 29, 2004 09:31 AM
dsosa51
Jun 2, 2004 10:35 AM
