ticking noise in engine! ran low on oil. need help asap!
Old Oct 22, 2006 | 01:37 AM
D16Y8-JDMYO's Avatar
Default ticking noise in engine! ran low on oil. need help asap!
oh
Old Oct 22, 2006 | 05:18 AM
dowdle's Avatar
Default Re: ticking noise in engine! ran low on oil. need help asap! (D16Y8-JDMYO)
if you ran it low on oil it could be a spun rod bearing. Had the same thing happen to me right after i got my civic and it was a spun rod bearing.
Old Oct 22, 2006 | 06:19 AM
nighttrain33's Avatar
Have you checked the oil level recently? If it's a spun bearing, you could be burning more oil than normal.
-Shane
Old Oct 22, 2006 | 10:09 AM
Default Re: ticking noise in engine! ran low on oil. need help asap! (nighttrain33)
i heard that a spun rod bearing would increase in noise or frequency as rpm goes up? is there anyway to fix it?
Old Oct 22, 2006 | 01:21 PM
helpz000rrrrrrrrr
Old Oct 22, 2006 | 02:45 PM
trujdmek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Y8-JDMYO &raquo;</TD></TR><TR><TD CLASS="quote">i heard that a spun rod bearing would increase in noise or frequency as rpm goes up? is there anyway to fix it?</TD></TR></TABLE>
if you SOP driving the ca rbefore it gets to ad for repair you can get new bearings if you've been driving it for long then either the rod will go through the oil pan or the crank will be damaged
Old Oct 22, 2006 | 04:02 PM
thahuhstunna's Avatar
Default Re: ticking noise in engine! ran low on oil. need help asap! (trujdmek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trujdmek &raquo;</TD></TR><TR><TD CLASS="quote"> or the crank will be damaged</TD></TR></TABLE>
more often than not, this is the case. i don't understand why people just can't maintain their vehicles. i used to feel sorry for these people who incur huge repair costs due to their negligence. not anymore.
092eg6
14
Mar 28, 2010 09:18 AM
Dyzee
10
Apr 28, 2004 11:56 AM
tha Big EZ
Jul 17, 2003 08:40 PM
espanol
Apr 20, 2003 10:04 AM
