Sleeve block deck with o-ring?
Old Oct 22, 2006 | 01:15 AM
integraboosted's Avatar
Default Sleeve block deck with o-ring?
I have a golden eagle sleeve block, deck with o-ring. I noticed the sleeves are a bit higher than the deck surface. Do you guys have the same expeirience with this
block and sleeve decking. Because the deck surface is not flat even with the sleeve. Would it affect with the headgasket and have any issue at all from leaking? Or I should just get the deck of the block flat surface even with the sleeve, plz help!! thanks.
Old Oct 22, 2006 | 01:30 AM
siblues's Avatar
Default Re: Sleeve block deck with o-ring? (integraboosted)
That is called a stepped deck and it is there specifically to help the headgasket seal.It is raised to give the headgasket a little better bite on the headgasket
Old Oct 22, 2006 | 01:55 AM
Default Re: Sleeve block deck with o-ring? (siblues)
would the headgasket seal even better with o-ring and stepdecking?
Old Oct 22, 2006 | 02:06 AM
siblues's Avatar
Usually its either one or the other.I think the most common method used now is step decking.
Old Oct 22, 2006 | 02:14 AM
Because i have both stepdeck and o-ring done so it will be even better one way or another.
Old Oct 22, 2006 | 02:30 AM
D@nnY's Avatar
If its oringed its still stepdecked but not as much
Old Oct 22, 2006 | 06:22 AM
sc4dr's Avatar
Default Re: Sleeve block deck with o-ring? (D@nnY)
Justice stepdecked, and o-ringed my block. When this is done you would usually use a sock headgasket, or A/M stock thickness headgasket. I think you'll probably here a lot of opinions on this, but I'll give it to my man Jim
TurboB16A300Hpteg
Feb 3, 2008 08:39 AM
cotten_itr
Aug 19, 2007 01:21 PM
West Werks
21
Aug 9, 2004 10:36 PM
slug
Jan 21, 2004 10:29 AM
