Adjusting Valves Q's.
Old Oct 22, 2006 | 12:36 AM
russianswty's Avatar
Default Adjusting Valves Q's.
what is this adjusting valves? I hear all the time about people adjusting the valves?
So what is this about, why would I need to adjust the valves. When would I need to do that.
Old Oct 22, 2006 | 06:07 AM
Lil Red CRXsi's Avatar
Default Re: Adjusting Valves Q's. (russianswty)
Yes,they need to be adjusted at times.Not sure on the mile interval,but if you're hearing them making noise-time to do it.
Old Oct 22, 2006 | 06:15 AM
mrtoastyjr's Avatar
Default Re: Adjusting Valves Q's. (Lil Red CRXsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Lil Red CRXsi &raquo;</TD></TR><TR><TD CLASS="quote">Not sure on the mile interval,</TD></TR></TABLE>
honda says for our cars every 30,000 miles.
basically you adjust the valve lash, or the space between the rocker and the valve tip. as the camshaft, valve tip, and rockers wear the space becomes bigger effectivly changing your valve timing. its also a good idea to keep the valves from getting damaged.
laboyon
Aug 14, 2008 05:08 PM
VTECcnIT
Nov 9, 2005 05:43 AM
GSRVTEC1
Oct 31, 2005 01:19 PM
Baron55
Aug 9, 2005 03:27 PM
