How do I notice a problem with my rod bearings?
Old Oct 21, 2006 | 10:01 PM
B20inDCinLBC's Avatar
Default How do I notice a problem with my rod bearings?
Ok, here's the deal. B20Vtec, motor was from PasswordJDM. My guy installed my vtec head last weekend and i think i could probably messed up my rod bearings... not too sure though. How can I make sure it is that? I had a valve adjustment already and i still hear it. I don't hear it at idle though, only when I gas it. Please help.
Old Oct 21, 2006 | 11:31 PM
ef
Old Oct 21, 2006 | 11:53 PM
92TypeR's Avatar
FSAE
Default Re: How do I notice a problem with my rod bearings? (B20inDCinLBC)
You can only inspect bearings visually.
You can drop your oil pan and pull the rods/pistons out and inspect the bearings that way, or pull the motor and dissassemble. I prefer the later, mainly because I hate having oil drip over me while I work.
Old Oct 22, 2006 | 12:39 AM
Default Re: How do I notice a problem with my rod bearings? (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">You can only inspect bearings visually.
You can drop your oil pan and pull the rods/pistons out and inspect the bearings that way, or pull the motor and dissassemble. I prefer the later, mainly because I hate having oil drip over me while I work.</TD></TR></TABLE>
So i can't really determine if it's my rod bearings just from hear it? Lets just say, I did expletive up my rod bearings, what effect would it have on my engine? Such as crazy *** noise, cause other problems? The car is untuned using a b16 base map on a b20vtec. I took it to 7200 and from then, I noticed this problem..
Old Oct 22, 2006 | 09:23 AM
92TypeR's Avatar
FSAE
Rod knock is a condition where if the rod bearing(s) get scored, they loose the ability to hold oil pressure and you hear a "knocking" sound.
Old Oct 22, 2006 | 09:43 AM
bump for some more side effects.
bb4socal
Feb 1, 2007 01:28 PM
94-integra-ls
May 8, 2006 03:37 PM
svmnredracr
Sep 15, 2004 08:11 PM
espanol
Apr 20, 2003 10:04 AM
B20zvtecek
Oct 28, 2002 07:11 AM
