OBD D16
Old Oct 21, 2006 | 09:39 PM
91slowhatch's Avatar
Default OBD2 D16
I am thinking of putting a OBD2 d16 in my hatch to replace the d15, what i needed other them the dpfi to mpfi? can i use my cable trans and clutch?
Modified by 91slowhatch at 6:42 PM 10/22/2006
Old Oct 21, 2006 | 10:09 PM
charlee's Avatar
Default Re: OBD D16 (91slowhatch)
why not obd1? its easier
Old Oct 22, 2006 | 09:19 AM
Default Re: OBD D16 (charlee)
Its what i have accese to that i know runs and works properly
Old Oct 22, 2006 | 09:37 AM
charlee's Avatar
soo. do you have a complete d16y8? (thats what im guesing you have)
Old Oct 22, 2006 | 05:43 PM
no its just a regular D16 out of a 98 hatch
Old Oct 22, 2006 | 06:06 PM
STREETWERKZ's Avatar
if youre doing this on a budget.... converting to obd-2 is gonna be a bitch.
use the D16y7 out of the 98 hatch.
swap on a D16a6 manifold, injectors, TB, fuel rail, convert to MPFI, resistor box, and pm6 ECU.
yes, you can use your current clutch and transmission. but i recommend using an SI transmission.
Old Oct 22, 2006 | 06:08 PM
civicjdmb16a's Avatar
Default Re: OBD D16 (STREETWERKZ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STREETWERKZ &raquo;</TD></TR><TR><TD CLASS="quote">if youre doing this on a budget.... converting to obd-2 is gonna be a bitch.
yes, you can use your current clutch and transmission. but i recommend using an SI transmission. </TD></TR></TABLE>
Old Oct 22, 2006 | 06:41 PM
NikoZai's Avatar
All true. Or run OBD1 components, then you won't need to change the dizzy.
Rywire can do all the wiring work if you're not up to it.
Call with any other questions, always happy to help ~ Peter @ Rywire
PoonAndSpoon
Jul 6, 2011 07:09 PM
o_fatmike_o
Oct 2, 2007 10:40 AM
isaacson06
May 15, 2007 08:48 AM
impactblue2ner
May 27, 2004 05:52 PM
