Tried everything but still wont start...
Old Oct 21, 2006 | 09:12 PM
aznsins88's Avatar
Default Tried everything but still wont start...
Posting this for a friend. First of all he drives a Civic hatch with a obd1 gsr swap. Couple nights ago he drove his car and it was driving great, nothing wrong with it. The next day, he started it up, it did but as he backed out of the driveway, the car died. We check the spark plug wires and the one all the way on the driver side was coated with this white powder and we dont know what it was, and the spark plug that it plugged into was filled with like oil and dirt. So we cleaned it off and it still doesnt start up. We checked the distributor and compression and they were fine also. We try cranking it and you can hear the starter turning but it doesnt start. We are very bummed and dont know whats going on. Anyone have any ideas? The car doesnt not throw any check engine lights.
~Eric
Old Oct 21, 2006 | 09:39 PM
aznsins88's Avatar
going to sleep bump
hopefully someone can help my friend out
~Eric
Old Oct 21, 2006 | 09:40 PM
IntegraType-R's Avatar
Default Re: (aznsins88)
timing, check the timing belt, he probably jumped a lot more then a few teeth.
Old Oct 21, 2006 | 09:51 PM
aznsins88's Avatar
alright, ill tell him to check that as soon as it stops snowing...yes its snowing here already...fucked up i kno.
Old Oct 21, 2006 | 10:57 PM
gsr x civic's Avatar
does he have some sort of aftermarket ecu?
this kind of happened to me in a way. . my car just didn't want to start. it would crank, but not turn over. after a week of checking problems, i came to the conclusion that it had to be fuses.
turns out it was my ecu fuse that blew, for some god forsaken reason. check the fuses, make sure everything isn't blown
let us know what happened!
Old Oct 21, 2006 | 11:19 PM
HoUTX98GSR's Avatar
Default Re: (gsr x civic)
check the ignitor inside the dizzy.
Old Oct 22, 2006 | 06:48 AM
aznsins88's Avatar
alright ill have him check the ecu and fuses...i think hes running the p72 but im not sure, just guessing since he has a gsr motor. How would we go to check the ignitor?
Old Oct 22, 2006 | 07:28 AM
Danziver's Avatar
Default Re: (HoUTX98GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoUTX98GSR &raquo;</TD></TR><TR><TD CLASS="quote">check the ignitor inside the dizzy.</TD></TR></TABLE>
x2
I have had this problem before. Are you getting spark?
Old Oct 22, 2006 | 07:35 AM
aznsins88's Avatar
yea we're getting spark, could it be anything else? We tried hitting the starter to try to get the car to start but no luck.
Pworld925
Dec 31, 2011 12:24 PM
91EF919
Mar 31, 2011 10:15 PM
LMdb2teggy
May 24, 2010 12:29 PM
corince06
Nov 17, 2008 08:28 AM
MetalKill
10
Jan 30, 2003 07:42 AM
