Suspension & Brakes Theory, alignment, spring rates....
Camber Kit
Old Oct 21, 2006 | 08:54 PM
JRTegman987's Avatar
Default Camber Kit
so im wondering if i should just get a camber kit... i dont plan on slamming my car im on s-techs now but im switching to Skunk 2 Full Coilovers soon/maybe spring time
Is there a downside to having a camber kit?
my thoughts are:
i believe its lighter (not a big deal)
poly bushings
adjustable to maybe get stock camber when on a slight drop?
i just dont want to get it and then run into an unforseen problem
Old Oct 21, 2006 | 09:31 PM
Tornadom's Avatar
Default Re: Camber Kit (JRTegman987)
I have a camber kit, and enjoy it. There are differnt types, and brands of camber kits. For the front, I use a new (modified stock) upper control arm, that allows for sliding the upper ball joint inward, or outward, thus changing the camber. I guess it is possible for the settings to slip, but I haven't had that happen (after 3 years, and 55,000 miles on the Skunk2 kit)
Others will disagree. This has been cover 143,365.8 times... so be prepared for what's next.
Old Oct 22, 2006 | 05:59 AM
RSX-R's Avatar
Default Re: Camber Kit (Tornadom)
well since your only lowering it at a minimal. then it wont be neccessary but if you plan on slamming it later for some reasons, then you might want to consider a camber kit.
Old Oct 22, 2006 | 07:27 AM
Default Re: Camber Kit (RSX-R)
so basically the only downside would be it possibly slipping?
Old Oct 22, 2006 | 04:52 PM
Tornadom's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JRTegman987 &raquo;</TD></TR><TR><TD CLASS="quote">so basically the only downside would be it possibly slipping?</TD></TR></TABLE>
Depending on the type of kit you use. The Skunk2 kit (which is all that I have experience with) is setup pretty well. The only problem that I can forsee is the setting slipping, thus changing your alignment. I imagine other things could happen, but I have had zero problems with mine after this time. I am lowered about 2" in the front. I run 1.2 degrees negative camber up front.
Old Oct 22, 2006 | 11:38 PM
TunerN00b's Avatar
Downsides also include:
Reduced suspension travel
Polyurethane bushing squeek
I wouldn't bother with a kit, unless you're trying to get more negative camber for handling purposes. For daily use, just get the toe set correctly and enjoy the money you would have spent elsewhere.
jdmeg6honda
Suspension & Brakes
Apr 16, 2011 10:25 AM
FLACO EM1
Nov 27, 2008 01:39 PM
KanzenR95GSR
Apr 22, 2004 01:21 PM
lsvtec_DA
Feb 25, 2004 09:59 PM
Jason C SBB
Sep 8, 2003 08:09 AM
