Timing Belt Help (please)
I'm about to replace my timing belt and want to know if the brand matters. In particular, I'm looking at the following ebay auction which uses a Conti/Bando belt. Does anyone have any feedback on the brand of the timing belt? In my search I've found that Gates timing belts are more expensive. Is there a reason for this? Thanks for your help
http://cgi.ebay.com/ebaymotors...59208
I have always endorsed Gates in my parts experience. I have sold many of them, and have never heard a bad comment about them. I have even used their timing belts for my own cars, and as well as their accessory belts.
from me.
NHRA doesn't use them because they are flimsy. Just remember, you get what you pay for. Case in point: https://honda-tech.com/zerothread?id=1788302
Do you wanna risk damaging your motor to save a few bucks?
And PLEASE, PLEASE replace that water pump and while you are in there.
from me.NHRA doesn't use them because they are flimsy. Just remember, you get what you pay for. Case in point: https://honda-tech.com/zerothread?id=1788302
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dyslogical »</TD></TR><TR><TD CLASS="quote">Yep, I'm replacing the water pump as well. Thanks.
Do you have any recomendations on where (online) to buy timing belt kits/water pumps? Thanks</TD></TR></TABLE>
If you're looking for all OEM parts, check out HondaAutomotiveParts.com
I just ordered a timing belt, tensioner, waterpump and thermostat for $150 shipped. Cheaper than all of the aftermarket parts at the local stores.
Thanks for the website, however, I'm not finding timing belts in any of the sections. I'm searching under the Honda Parts Catalog. Any help? And anyone have opinions on Bando? Thanks
Ok, I'm making progress.
I used the part number search for the timing belt and water pump:
Timing belt part no. 14400-P2F-A01
Water pump part no. 19200-P2A-A01
However, I can't find the tensioner. I'm using the following for a search:
Tensioner part no. 14510-P08-004
Ok, thanks.
Now my problem is that they list 2 tensioner sets. Both sets are the same price but they have different product numbers. One is 18215 and the other is 18216. I have a 1997 Civic HX. Does anyone know what the difference is between those two tensioner sets? Thanks.
Why can't you just use the drop down menus?
It's under the same heading as the timing belt.
http://www.hondaautomotivepart...81%29
edit: Either tensioner should work.
tricura
211
Sep 30, 2009 08:52 AM
