need some help please
Old Oct 21, 2006 | 07:40 PM
vtecsi00's Avatar
Default need some help please
finished build on my b16a2 build and i can't get the car to start now........check to make sure everything is line up as in timing belt( everything is at tdc)...valves are adjusted,cam gears are at 0,spark at the wires,distributor rotor is at the right mark( not 180 off).....getting fuel to fuel rail....when i start the car it sounds like it wants to start but won't start .........can't think of anything else that could be wrong or not setup up right.......going to check compression tomoorow.......any help would be appreciated.............
Old Oct 21, 2006 | 10:45 PM
vtecsi00's Avatar
Default Re: need some help please (vtecsi00)
does anyone have an explanation or theory please would like to get my car running
Old Oct 22, 2006 | 07:50 AM
JDM94EG28's Avatar
check all main fuses,check if main relay is clicking at all ,and aslo try swaping ecu
Old Oct 22, 2006 | 07:25 PM
vtecsi00's Avatar
Default Re: need some help please (JDM94EG28)
tried using stock ecu and p28 ecu chipped.....will check all main fuses thank you
Old Oct 22, 2006 | 09:41 PM
vtecsi00's Avatar
checked fuses and everything is good.......taking in the battery to work to get it charged
Old Oct 24, 2006 | 10:50 PM
vtecsi00's Avatar
pm back thanks for the reply for help
smbignick
Aug 18, 2013 01:47 PM
91rexhf
10
Dec 27, 2008 05:06 PM
jr000
Nov 16, 2008 04:14 PM
b16a4
Apr 26, 2007 06:21 PM
lude97dude
Jan 21, 2003 08:53 PM
