Can I use crx si fuel rail with d16z6 IM
Old Oct 21, 2006 | 05:07 PM
JUN.'s Avatar
Default Can I use crx si fuel rail with d16z6 IM
Old Oct 21, 2006 | 06:44 PM
BlueCrxNC's Avatar
Nope... OBD-0 has slightly different mounting points than OBD-1
Tried it myself before. One or two holes are moved slightly. Why Honda did that I do not know.
Old Oct 21, 2006 | 07:19 PM
JUN.'s Avatar
Default Re: (BlueCrxNC)
too bad,,,, well more money to spend
Old Oct 21, 2006 | 07:34 PM
JUN.'s Avatar
Default Re: Can I use crx si fuel rail with d16z6 IM (JUN.)
so which fuel rail can I use other than d16z6 one ???????
what about the injectors ? do CRX si ones bolt to the d16z6 fuel rail ??
Old Oct 21, 2006 | 11:25 PM
BlueCrxNC's Avatar
Just want to clarify in case I've confused you in anyway... All D-Series Intake Maninfolds will bolt up to your Head. But you cannot swap Fuel Rails between OBD-0 and OBD-1. Just wanted to make sure that was clear. I re-read my post and your reply and it almost sounded like you thought you had to reuse the OBD-0 Intake rather than the Z6.
Wish I knew of other OEM Fuel Rails you could use. You could always use the Z6 Intake Manifold with an aftermarket fuel rail for the 92-95 Civic or buy an OEM OBD-1 rail.
You can use any injectors you want from Honda/Acura. Just make sure you remove your injector resistor box if you use Saturated Injectors (92+ Civic) OR keep your injector resistor box for Peak and Hold Injectors (91- Civic/CRX etc.) Do avoid HF Fuel Injectors; in 1988 and 1989 they used 190 cc while 90-91 and any other trim levels use 240 cc. https://honda-tech.com/zerothread?id=1788020
Old Oct 22, 2006 | 06:44 AM
JUN.'s Avatar
thanks man, I knew that I could use crx si intake manifold with everything but i want to use the Z6 one because performs and looks better
Old Oct 22, 2006 | 08:34 AM
BlueCrxNC's Avatar
Default Re: (JUN.)
I agree. I looks ALOT better.
Old Oct 22, 2006 | 09:18 AM
JUN.'s Avatar
what about crx si FPR ? Does it bolt to Z6 fuel rail ?
Old Oct 22, 2006 | 03:42 PM
d16vtecx's Avatar
Default Re: (JUN.)
yes it does
EG-SIXV-TEC
Apr 21, 2013 11:45 PM
tyler100
Apr 25, 2008 06:53 AM
JUN.
Oct 22, 2006 07:25 PM
ldanphanl
Apr 14, 2005 08:53 AM
