just changed the 5th gear off my si tranny with an ls.... wineing now need help
ok bought the 5th gear from honda... 60$ was like y not better gas milage now then i took it to a machine shop so they could take 5th off my si and replace it with 5th from ls. well now when i shift into 5th it wines alot. will this be a problem or does anyone have any answers. im about to drive across country and really don't want to drive with it like this.
ok here are the problems:
1) 5th gear that got replaced grinds
2) absolutly no MPH sensor works sometimes i was crusing about 30 it was bouncing around 80-120
3) randomly no power comes from the gear even if i downshift if the rpms go to 0 then i can shift it back into gear
ok here is what was done:
new flywheel
new clutch kit
new throughout bearing
new clutch slave cylinder
Modified by Jammersplace at 8:59 PM 10/21/2006
new flywheel
new clutch kit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jim Truett »</TD></TR><TR><TD CLASS="quote">You replaced both fifth gears, right?</TD></TR></TABLE>
the lack S at the end of the word Gear , makes me think no
ok ill get 5th fixed but sill have problems with me traveling down the road and the tranny not having any power till i stop and start again
you mean the engine revs but the power doesn't get to the floor?
or is your engine hesitating?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jammersplace »</TD></TR><TR><TD CLASS="quote">ok ill get 5th fixed but sill have problems with me traveling down the road and the tranny not having any power till i stop and start again</TD></TR></TABLE>
Is it just 5th that acts like this?
5th gear it had no power so i pushed the pedel to the floor to see still no power downshift to 4th still no power and again 3rd but if i stop and start again i get the power back.
no ordering it and we either will put it on or get the old one and put it on.
I'm not really sure of an answer but if everything worked before you had the 5th grear in, I think it was a waste of money to change all that other stuff...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_V_TurboSi »</TD></TR><TR><TD CLASS="quote">I'm not really sure of an answer but if everything worked before you had the 5th grear in, I think it was a waste of money to change all that other stuff...</TD></TR></TABLE>
Obviously something was done incorrectly. So, no, it was not a waste of money.
I can see how you misundestood my point.
the way I read it- " I bought an ls 5th gear and had a machine shop install it, now the tranny whines and 5th gear grinds and since then I've replaced flywheel, clutch, slave cylinder and throwout bearing"
Since he didnt mention the replacement of the gear in the list of items I assumed he's replaced those items AFTER the noise started. Which would explain my post
ok the full story. pulled the engine out to get it sleeved. ended up getting aebs sleeves je 9:1 pistons and eagle rods lighter flywheel and new cluth. while it was out i got the machine shop to go ahead and replace the gear on the counter shaft. looked through the whole helms and i guess i missed the one on the main shaft. So ill order it or put the old one back on. im driving 1600 miles the added gas milage would help
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jammersplace »</TD></TR><TR><TD CLASS="quote">oh and do you really need a transmission shop to press off and put a new gear on?</TD></TR></TABLE>
No, but a good transmission shop would have noticed the mismatched gears.
