99 LX....whining noise coming from front at highway speeds
Old Oct 21, 2006 | 03:04 PM
Playa_FL's Avatar
Default 99 LX....whining noise coming from front at highway speeds
My 99 Accord LX is making a whining noise at highway speeds, when the windows are up and the music is off, you can hear it very well. Wheel Bearing maybe? Tranny? Anyone else have this problem? Also, is it a know problem for the VTEC oil pressure sensor/switch to take a dump? My VTEC is malfunctioning and the guy who trouble shot the code says that when he put a volt meter on the switch, it didnt read anything when the car was running. Is it supposed to read a voltage when running or only when the VTEC kicks in? Is VTEC always working, or just at a certain RPM? Its my first accord. Thanks for any help.
Old Oct 23, 2006 | 01:12 PM
Playa_FL's Avatar
Default Re: 99 LX....whining noise coming from front at highway speeds (Playa_FL)
bump for any help....
Old Oct 23, 2006 | 05:51 PM
Jigoku Z's Avatar
The noise is probably your diff. carrier bearing in your transmission. Does the whining go away for a sec when your car shifts?
Old Oct 23, 2006 | 05:54 PM
Playa_FL's Avatar
Default Re: (Jigoku Z)
No it doesnt. Its consistent during shifts. The faster you go, the louder it gets.
Old Oct 24, 2006 | 01:53 AM
AFAccord's Avatar
Default Re: (Playa_FL)
Wheel bearings will correlate to your speed, but from my experience, the wheel bearing has more of a droning sound, or a roar, rather than a whine.
Old Oct 24, 2006 | 02:20 AM
YeuEmMaiMai's Avatar
when you are at highway speeds, gently turn wheels left to right and see if the noise changes, if not, it is not your bearings. If it does change, it is your bearings.
most likely it is your differential causing the noise due to the taper bearings being excessively worn. This is a common problem in these cars particularly the V6 ones......but the I4 can be affected as well
Old Oct 24, 2006 | 01:03 PM
Playa_FL's Avatar
Default Re: 99 LX....whining noise coming from front at highway speeds (YeuEmMaiMai)
ok finally something to point me in the right direction!! taper bearings being excessively worn........Do i have to pull the tranny to change those? If not, how do i change them?
Old Oct 24, 2006 | 03:14 PM
yes trans has to be pulled becuase they have to dissassemble it.
Sorry...
Yes you can drive it until the axle seals start leaking and if you have complete service, you can try asking HOA for goodwill assistance if your car is under 100K
Modified by YeuEmMaiMai at 8:20 PM 10/24/2006
Old Oct 24, 2006 | 05:15 PM
Playa_FL's Avatar
ok so what would happen if i just left it as is? Would it cause my trans to eventually fail?
bambbrose
Oct 11, 2015 08:01 AM
edu-dba@hotmail
Aug 21, 2013 01:25 AM
Bird333
Jan 31, 2013 06:40 AM
shane2121
Jan 19, 2013 12:31 PM
gallowmay
Aug 27, 2004 03:58 PM
