Broken thermostat housing on 95 accord EX vtec, HELP!!!
Old Oct 21, 2006 | 02:14 PM
acslader's Avatar
Default Broken thermostat housing on 95 accord EX vtec, HELP!!!
Was changin the t-stat, and could not see second bolt at ALL, so pryed the housing off and saw that there was a second bolt. (I know im an idiot, been told that by everyone who knows about the situation. Feel free to call me anything, as long as you are of some help.) So the piece where the thread is at came off and i dont know what to do. The piece that came off was attached to the egine block. It is not metal, atleast not any metal that can be picked up with a magnet, so i dont think i can weld it. I tried J-B weld but it didnt stick on while i was tryin to screw the bolt back in. PLEASE GIVE ME ANY SUGGESTIONS, I NEEDS MY CAR!!!
Old Oct 21, 2006 | 06:26 PM
pos_cd5's Avatar
Default Re: Broken thermostat housing on 95 accord EX vtec, HELP!!! (acslader)
buy a new one?
Old Oct 23, 2006 | 08:39 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acslader &raquo;</TD></TR><TR><TD CLASS="quote">... The piece that came off was attached to the egine block...</TD></TR></TABLE>Sounds like #8, thermostat case. It's bolted to the engine block.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by acslader &raquo;</TD></TR><TR><TD CLASS="quote">... It is not metal, atleast not any metal that can be picked up with a magnet, so i dont think i can weld it...</TD></TR></TABLE>It's aluminum. If you don't know already how to weld aluminum, don't try it.
Old Oct 23, 2006 | 06:35 PM
acslader's Avatar
Default Re: Broken thermostat housing on 95 accord EX vtec, HELP!!! (JimBlake)
THANKS MANG!!! You've been more helpful than like the 20 ppl i know personally and asked for help. Once again, your help has been GREATLY APPRECIATED!!!!
Old Oct 23, 2006 | 07:00 PM
momstaxi's Avatar
hmm, as long as the actual coolant passage isnt cracked just replace with only the upper bolt holding it, it will be fine.
Old Oct 23, 2006 | 09:02 PM
JimBlake's Avatar
Default Re: Broken thermostat housing on 95 accord EX vtec, HELP!!! (momstaxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by momstaxi &raquo;</TD></TR><TR><TD CLASS="quote">hmm, as long as the actual coolant passage isnt cracked just replace with only the upper bolt holding it, it will be fine.</TD></TR></TABLE>Maybe, but I'd be worried about the OTHER side cracking because now it has to carry far more than double the load.
Old Oct 23, 2006 | 09:38 PM
pos_cd5's Avatar
with only 1 bolt holding it on and an uneven amount of pressure around it wouldnt you risk a chance of leaking water since your cooling system is under pressure?
Old Oct 24, 2006 | 05:14 AM
momstaxi's Avatar
Default Re: Broken thermostat housing on 95 accord EX vtec, HELP!!! (pos_cd5)
its been done before with no problems...
C_Rock77
Feb 6, 2021 09:33 AM
suprgato
Dec 1, 2007 08:25 PM
Soon2bH2b
Sep 25, 2007 10:09 AM
Soon2bH2b
Sep 25, 2007 08:29 AM
Mr EJ1 203
May 12, 2006 06:47 PM
