GSR Head Gasket
Old Oct 21, 2006 | 02:09 PM
LILSOWEK's Avatar
Default GSR Head Gasket
Ok im building a gsr engine that was bored .5mm so its now 81.5mm, i want to know if i can use the stock head gasket or which one should i use. i read in some online stores that the stock size gaskets are for 81mm to 81.50mm, is that true????
Old Oct 21, 2006 | 03:15 PM
Beau Gotti's Avatar
yes a stock gasket is 81.5 mm
Old Oct 22, 2006 | 10:53 PM
LILSOWEK's Avatar
i thought a stock gasket was 81mm
Old Oct 23, 2006 | 04:09 AM
Beau Gotti's Avatar
the bore is 81mm the headgasket is acctually 81.5 you can use as much as a 82mm headgasket.
Old Oct 23, 2006 | 06:37 PM
LILSOWEK's Avatar
ok thanks!!
Old Oct 25, 2006 | 06:06 AM
M2S~Jaime's Avatar
Really??? So LS and GSR headgaskets are the same???
chicklet
May 24, 2017 11:13 AM
radeon
Jun 19, 2005 04:57 PM
thegrayghost
Feb 15, 2005 05:46 PM
boomslang
Sep 18, 2002 12:48 PM
therealnapster
Sep 10, 2001 01:32 PM
