siR cluster troubles... help!
Old Oct 21, 2006 | 02:08 PM
ballermc5's Avatar
Default siR cluster troubles... help!
just got done installing/wiring up my jdm siR gauge cluster in my 88 civic hatch...
the speedometer is the only thing not working.
i've installed the electric vss, and i ran the wires for it.
the vss is supposed to have 3 wires coming out... ground, signal, and power
signal splits half to gauge cluster, and half to pin B16 on the jdm ecu...
i spliced the power from another switched power wire going into a connector in the gauge cluster... and grounded on the steering column...
so whats wrong? i need help
any suggestions would be helpful...
what is the correct pinout of the vss connector, because i just had to put wires directly into it cuz i didnt have a connector to fit it...
Old Oct 21, 2006 | 03:50 PM
ballermc5's Avatar
Default Re: siR cluster troubles... help! (ballermc5)
help
Old Oct 22, 2006 | 12:05 PM
ballermc5's Avatar
still not working
Old Oct 23, 2006 | 05:15 PM
ballermc5's Avatar
bump
Old Oct 23, 2006 | 06:28 PM
wood 1's Avatar
What year model is the cluster?
Old Oct 24, 2006 | 07:45 PM
ballermc5's Avatar
Default Re: siR cluster troubles... help! (wood 1)
i assume its a 90-91
Old Oct 24, 2006 | 07:48 PM
Ak_ef9's Avatar
On my cluster the wiring went like this.
as the clip is facing away form you it goes signal power ground. Maybe. All I know is that mine the power was in the middle.let me know if that works.
Old Oct 25, 2006 | 06:15 AM
ballermc5's Avatar
i'll try that when i go home... but i've tried a bunch of different combinations, so i think the wiring problem is up by the cluster, or the vss is not gettin power, or the vss is bad...
Old Oct 25, 2006 | 06:32 AM
Loserkidwac's Avatar
Default Re: (ballermc5)
https://honda-tech.com/zerothread?id=1779838
There is my post from a while ago got some info that may help you...are you sure your wires are connected well on the VSS...i was going to ground mine to the thermo housing also run a inline fuse in your power just incase...HTH
Old Oct 25, 2006 | 10:08 AM
ballermc5's Avatar
ok so i think that my current vss is burnt up due to wrong wiring the first time i installed it... i'm going to test it when i get home to make sure
Old Oct 28, 2006 | 01:03 PM
ballermc5's Avatar
ok guys... i have a good vss in there, wired correctly... .and i rewired all the connections to the cluster and ecu that had anything to do with the speedo.... and the speedo still doesnt work...
what do i do?
is it a bad cluster?
how do i know if its a bad cluster?
Old Oct 28, 2006 | 01:29 PM
STDClayton's Avatar
i'm not trying to bash on you whatsoever... because it's your car and not mine... but why do people put jdm clusters on their cars? i could see it if you were in canada and everything was in km/h but that has got to be annoying remembering what speed you're travelling at in mph.
Old Oct 28, 2006 | 01:34 PM
88crxvtec's Avatar
Default Re: (STDClayton)
I know having a cluster stopping at 8k when i rev past that is a good reason.
Old Oct 28, 2006 | 03:36 PM
Ak_ef9's Avatar
I did it cuz it lok better and I since I shift at about 9200 I needed it. I didnt want to put a monster tach in. so I got this which was 150 shipped from hmotorsonline.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STDClayton &raquo;</TD></TR><TR><TD CLASS="quote">i'm not trying to bash on you whatsoever... because it's your car and not mine... but why do people put jdm clusters on their cars? i could see it if you were in canada and everything was in km/h but that has got to be annoying remembering what speed you're travelling at in mph.</TD></TR></TABLE>
Also this cluster is in properly now and not as off as it is in the picture.
Old Oct 28, 2006 | 03:52 PM
STDClayton's Avatar
Default Re: (88crxvtec)
touche
french_yogi
Apr 18, 2011 06:24 PM
twedter02
Sep 24, 2010 10:00 PM
ef-b16sedan
Jul 7, 2006 01:21 PM
RC211V
Honda Motorcycles
Oct 1, 2005 12:37 PM
