rotor removal
Old Oct 21, 2006 | 02:07 PM
anthony90si's Avatar
Default rotor removal
ok guys i never reall worked on accord dizzys. and i can't seem to find a way of removing the rotor. the dizzy cap is off and now there is a pretections cover and i can't take it off. whats is the trick. also if i have a dizzy for a 90 accord with internal coil can i interchange parts with an external coil dizzy.thank alot
Old Oct 21, 2006 | 02:12 PM
oh and how do i know if its obd1 or obd0. and its a 90ex from japan does that change anything? i am kinda confused. thanks
Old Oct 21, 2006 | 03:04 PM
ok i got it appart i though it was a screw on type like civic/integra. now is the igniter the same with both dizzys? thanks
Old Oct 22, 2006 | 06:29 AM
Duane_in_Japan's Avatar
Default Re: (anthony90si)
follow the ignition/ignitor control module post near the top of this page, it states that all or most of the ICM are the same, they must look the same of course.
Old Oct 22, 2006 | 01:29 PM
ah ya they don't realy looks exactly the same
Old Oct 23, 2006 | 04:03 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: rotor removal (anthony90si)
you can always go onto HAP or SLHonda and look up the two parts and compair the numbers to see if they are the same.
I've also called the parts counter at the local dealer and asked them to check if parts from one model were the same as another model. Could do that as well.
janek
Mar 14, 2013 06:09 PM
05integra84
Mar 7, 2013 06:49 PM
GWS372790
Aug 23, 2011 07:52 AM
Targa4Life
Aug 9, 2008 03:20 AM
BoOsTiN Dc2
Mar 25, 2004 09:58 AM
