Persistent CEL 10 with VAFC-II
Old Oct 21, 2006 | 01:21 PM
Chapster's Avatar
Default Persistent CEL 10 with VAFC-II
Here's the deal. Purchased a 93 Si with a blown B16A and GSR transmission. The car had has Intake, header, exhaust. The blown engine has skunk2 cams and valve springs so the guy had an VAFC-II wired in to tune this setup.
Purchase a new B16A longblock OBD-I. Installed the motor last night, start up fine. Initially threw some code but i worked them out. The only code left is #10. The IAT sensor is mounted to the manifold and is plugged into (red and green wires). everything i've tried so far has not helped. Resetting the ECU, messing with AFC, etc. How do i test if the sensor is bad? Any help? Any ideas?
andywtflol
27
Nov 4, 2012 10:14 AM
BoostnEK6206
Oct 18, 2007 10:53 AM
jetblack
May 16, 2006 06:20 PM
Red2001GSR
Feb 19, 2002 02:36 AM
The Punisher
Sep 1, 2001 03:11 PM
