Bulb size on 99-00 Foglights?
Old Oct 21, 2006 | 12:33 PM
DFW's Avatar
DFW
Default Bulb size on 99-00 Foglights?
What's the bulb size on Depo OEM style 99-00 Civic foglights? And what's a good bulb, I want it really yellow.
Old Oct 21, 2006 | 01:05 PM
Asimo-Tech's Avatar
Default Re: Bulb size on 99-00 Foglights? (DFW)
bulbs are ((( H3 )))) Just drop 3000k H3 hid kit... cant get brighter yellow than that...
Old Oct 21, 2006 | 02:30 PM
Padawan's Avatar
Darth ModerVader
PIAA Ion Crystal are some of the best in terms of producing yellow light with a minimal loss in output, while also maintaining the beam pattern that the lights were designed to generate.
Old Oct 21, 2006 | 02:56 PM
DFW's Avatar
DFW
Default Re: Bulb size on 99-00 Foglights? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">PIAA Ion Crystal are some of the best in terms of producing yellow light with a minimal loss in output, while also maintaining the beam pattern that the lights were designed to generate. </TD></TR></TABLE>
Do you have any pictures with them on?
Old Oct 21, 2006 | 03:45 PM
Padawan's Avatar
Darth ModerVader
Here are a couple that I found using Google, and there are plenty more if you want to search on your own:
Old Oct 21, 2006 | 09:01 PM
DFW's Avatar
DFW
Looks good, anyone else have any suggestions?
Old Oct 21, 2006 | 09:22 PM
GG99's Avatar
piaa ion crystal
Old Oct 21, 2006 | 10:00 PM
DFW's Avatar
DFW
Default Re: Bulb size on 99-00 Foglights? (GG99)
Humm, how would you wire the hid's into the fogs? Just splice the wires?
Old Oct 21, 2006 | 10:01 PM
t0p_sh0tta's Avatar
It's recommended that you run an upgraded wiring harness. There is a possibility that you will melt the stock wiring.
I can get HID kits with harnesses if you're interested.
Old Oct 21, 2006 | 10:02 PM
DFW's Avatar
DFW
Default Re: Bulb size on 99-00 Foglights? (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta &raquo;</TD></TR><TR><TD CLASS="quote">It's recommended that you run an upgraded wiring harness. There is a possibility that you will melt the stock wiring.
I can get HID kits with harnesses if you're interested.</TD></TR></TABLE>
What's the difference in the "upgraded harness"?
Old Oct 21, 2006 | 10:04 PM
t0p_sh0tta's Avatar
Thicker gauge wiring that's connected directly to the battery.
Basically, it's the same as a foglight harness.
Old Oct 21, 2006 | 10:05 PM
toekneexD's Avatar
sorry if im thread jacking .. not trying to... but is there a bulb diffrence in the OEM foglights and the DEPO foglights? i just ordered h1 bulbs for my oem foglights and i read up there about h3? i hope i didnt order the wrong one
Old Oct 22, 2006 | 02:37 AM
White95SiHB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DFW &raquo;</TD></TR><TR><TD CLASS="quote">Looks good, anyone else have any suggestions?</TD></TR></TABLE>
Piaa Ion Crystal will give out yellow light, however on the 99-00 foglights, when you look directly at the foglights they don't look yellow. I don't know if this will be a problem for you.
I installed a pair in my cousin's 00 Civic and another pair in my mom's driving lights on her van. When you look at the housing it looks like a regular bulb, but on the road it's yellow.
Just some FYI in case you wanted the yellow look (ie Lexus, Infiniti).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toekneexD &raquo;</TD></TR><TR><TD CLASS="quote">sorry if im thread jacking .. not trying to... but is there a bulb diffrence in the OEM foglights and the DEPO foglights? i just ordered h1 bulbs for my oem foglights and i read up there about h3? i hope i didnt order the wrong one </TD></TR></TABLE>
Yes, you ordered the wrong one. Notify them if you can and see if they'll let you do an exchange.
Old Oct 22, 2006 | 08:40 AM
DFW's Avatar
DFW
Default Re: Bulb size on 99-00 Foglights? (White95SiHB)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White95SiHB &raquo;</TD></TR><TR><TD CLASS="quote">Piaa Ion Crystal will give out yellow light, however on the 99-00 foglights, when you look directly at the foglights they don't look yellow. I don't know if this will be a problem for you.
I just noticed this last night. I want more yellow and the yellow look
Old Oct 22, 2006 | 11:21 AM
Try Luminics Bulbs, their H3 bulb has a yellow tint as opposed to Piaa's multi colored tint.
Tuner Eddy
Dec 11, 2007 05:38 AM
boomersz
Mar 17, 2007 09:01 AM
jdmstreethatch
Dec 10, 2004 09:30 PM
hasback*
Jun 9, 2004 09:41 AM
