Setting timing, which mark do i line up on the pulley... 3 marks? or one mark?
Old Oct 21, 2006 | 12:16 PM
philkehn's Avatar
Default Setting timing, which mark do i line up on the pulley... 3 marks? or one mark?
Okay my pulleys old and has no colors just lines... the haynes manual tells me to line up with the one line.... on my pulley theres a line by it self then a group of three lines.... which lines do i use???
Also there is no bottom cover on the engine to line up the crank pulley and i dont have a light or anything of that sort... how would i go about finishing this?
Old Oct 21, 2006 | 12:30 PM
Loserkidwac's Avatar
Default Re: Setting timing, which mark do i line up on the pulley... 3 marks? or one mark? (philkehn)
Well honestly the best way would be to pull the crank pulley off and use the mark on the oil pump...but if no you might be able to see it if you can get a flash light...to answer your originall question use the single line for the cam timing...the 3 lines are for the dizzy timing
Old Oct 21, 2006 | 12:37 PM
philkehn's Avatar
and the single line is just a couple inches to the right of the 3 lines correct??
Im suppose to line up the pulley line with the line on timing cover, however this si engine dont have a line, is there anything else i can use to line up the line... im not to familiar with the oil pump... how would i use the oil pump to do it??...
Old Oct 21, 2006 | 01:12 PM
Default Re: (philkehn)
Well this is from a LS motor but I believe all honda motors are the same
Old Oct 21, 2006 | 01:14 PM
fireant's Avatar
Default Re: (Loserkidwac)
The three lines represent what you use when you have a zero-set timing gun. The soliarty line farther aolng the pulley is for TDC and you can use it if you are using an advance timing light.
Old Oct 21, 2006 | 02:06 PM
philkehn's Avatar
Uhh i said i dont have a light thats the reason for the post...
In that picture is the oil pump actually behind the crank pulley?
in other words do I have to take off my pulleY?
Old Oct 23, 2006 | 06:23 AM
Yea its behind the pulley it sucks but if have no timing cover ts the next best way to line up the cam timing...
You should go invest in a light...
Old Oct 23, 2006 | 06:47 AM
crxnj's Avatar
so you're just trying to set the #1 piston to TDC? If so just look at the marks on the cam gears,,,And take out the spark plug for cylinder 1 and stick a long screwdriver in there,,then turn the motor till the screwdriver is all the way up and the cam gears are like this for #1 pistons at TDC....
Old Oct 23, 2006 | 08:20 AM
philkehn's Avatar
thanks, i didnt check back here in time, but i actually stuck the pole from my battery tie down into the #1 hole to find top dead center, threw the belt on and it running good, according to the guy i did it for anyways
black0hatch
Aug 27, 2009 05:54 PM
Civic-Kids
Sep 23, 2007 12:44 PM
b16a4
Sep 4, 2007 12:06 PM
lv6l
Nov 17, 2005 04:41 PM
lv6l
Nov 17, 2005 12:33 PM
