JDM D15b Turbo
Old Oct 21, 2006 | 11:55 AM
SupraRXZ's Avatar
Default JDM D15b Turbo
whats the difference between obd0 version of the JDM d15b and the obd1? besides the obd0 and obd1? anything different performance wise? and does it come with a cable tranny (obd0)? I was going to put this in my CRX HF, If I get the obd0 version can i use the same Dizzy from the HF or get a SI one? I wanted to get a SI ecu and chip it for vtec and get it programed for the turbo. or should i convert everything to obd1 and get a p28 and program that? cause from what I read keeping the resistor box is good when doing a turbo set up. is that true? That reason and Im sorta lazy to do a obd1 conversion and buyin obd1 stuff. And about the tranny can I use the d15b's tranny with HF axles and hubs and all that? I got more ?'s but this seems like a lot already
Thanks
Old Oct 21, 2006 | 11:59 AM
FIGARILA's Avatar
Default Re: JDM D15b Turbo (SupraRXZ)
i don't think the JDM d15b that we are all familar with came in obd-0.
Old Oct 21, 2006 | 12:00 PM
iphatcrxi's Avatar
Default Re: JDM D15b Turbo (Heron of Alexandria)
i think he's asking is it better to convert it to obd1 then to keep it obd0?
Old Oct 21, 2006 | 12:04 PM
SupraRXZ's Avatar
Default Re: JDM D15b Turbo (iphatcrxi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iphatcrxi &raquo;</TD></TR><TR><TD CLASS="quote">i think he's asking is it better to convert it to obd1 then to keep it obd0?</TD></TR></TABLE>
Basicly ya
Old Oct 21, 2006 | 12:05 PM
iphatcrxi's Avatar
then yes it's better to convert to obd1 for tuning purposes
Old Oct 21, 2006 | 12:10 PM
SupraRXZ's Avatar
and are all years of the d15b stage 3 vtec? or is it a specific year?
Old Oct 21, 2006 | 12:11 PM
iphatcrxi's Avatar
Default Re: (SupraRXZ)
i'm not completely sure of the years but mine isn't a stage 3 vtec
Old Oct 21, 2006 | 12:15 PM
SupraRXZ's Avatar
what year is yours? and I think to make it work you have to have the VTi ECU or whatever ECU goes with the d15b, it is said the d15b gets 54mpg stock, what are you getting? you probably modified yours but so am I, so i just wanna know
Old Oct 21, 2006 | 12:36 PM
v8Buster's Avatar
obd1 D15B is better for ECU 's and no not all D15bs are stage 3 vtec, mine is just VTEC lol
my car gets about 18 mpg because its running rich. but since i am obd1 i dont have the flashing light on my ECu to check the code its throwing, so not sure if its a map sensor or o2 sensor.
Old Oct 21, 2006 | 12:57 PM
SupraRXZ's Avatar
Default Re: (v8Buster)
from your experiences, is the d15b all its cracked up to be? I can get the motors for $180 complete so I was gunna get one for me and my brother, but I was gunna turbo mine. theres other ways to check for the ECU codes then the flashing light on the ECU, im sorta lazy to type it all but its pretty easy
Old Oct 21, 2006 | 01:27 PM
iphatcrxi's Avatar
well if you get a ecu jumper harness from rywire then you connect the orange and blue wires and the check engine light flashes to show codes, but i think for the money the d15b is pretty nice, 130hp, im using the p08 ECU that's for that motor, but im getting a p28 since i am going to tune it and sell the p08.
Old Oct 21, 2006 | 04:18 PM
si 2's Avatar
Default Re: (iphatcrxi)
the 3 stage vtec is very rare and that is obd-2 the obd-1 is just vtec thats the po8 ecu and jdm d15b vtec is a pretty good motor its a bang for your buck
This is what i posted because to many people dont know what they have
https://honda-tech.com/zerothread/1787145
Old Oct 21, 2006 | 06:50 PM
BlueCrxNC's Avatar
Default Re: (si 2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si 2 &raquo;</TD></TR><TR><TD CLASS="quote">the 3 stage vtec is very rare and that is obd-2 the obd-1 is just vtec thats the po8 ecu and jdm d15b vtec is a pretty good motor its a bang for your buck
https://honda-tech.com/zerothread/1787145</TD></TR></TABLE>
http://asia.vtec.net/article/d15b/
EnSAn
Jun 3, 2006 03:12 PM
DOHClessEF-9
12
Apr 21, 2005 06:07 PM
gvillehnut
Mar 10, 2003 10:24 AM
