Skunk2 Manifold Install???
hey guys i tried doin a search for this but had no luck...anyways i'm having a lil trouble hookin up this manifold...if anybody can help me out and give me some directions with this thing...it looks like i have some extra hoses and stuff that i have no clue what to do with...
first off this is goin onto a 97 gsr motor which is goin into a 92 teg so i'm also converting the motor to obd1...
pretty much all i have done is the throttle body, fuel rail and injectors figured out but everything else i'm kinda lost at....
so any help especially some diagrams or pics would be nice
you pretty much just put everything you took off on your intake manifold and put em on the skunk2. if there are extra hoses, it doesnt mean you need to use em. sometimes they put extra hoses just in case. just make sure everything is connected and there arent extra holes or unconnected vacuum lines.
You will have to "T" that water house line with a brass fitting. You just dont have an "extra" hose unless you want all your water to shoot out and fuggle up your block.
I believe all the Skunk2 manifolds are are all OBD2 based. Which means youll have an extra hose with no end to plug it into. Just buy a "T" fitting from Pep Boys. Good Luck!
civics4lyfe
Jun 7, 2015 12:44 PM
jkalex05
Aug 23, 2009 06:01 PM
