messed up suspension?
Old Oct 21, 2006 | 10:14 AM
silentdeath12886's Avatar
Default messed up suspension?
i posted in the suspension section as well to get as many answers as i can.
i have a 99 integra ls cpe dc4 with stock suspension. today i put in my jdm itr header and cat. when i was all done i noticed that my front driver side gap between tire and fender was really high. and then iw ent around the car and measured the front passenger and rear gaps to be 4 finger length gaps and the front had about 6. i drove it around for like 15 minutes and measured the gaps again and then the rear were 3 finger lengths while the front passenger was 5 and the front driver side was 4 finger lengths....what the hell is wrong with the front? bad shocks?
Old Oct 21, 2006 | 11:25 AM
AllMotorDan's Avatar
maybe you need new struts, have you looked to see if there blown?
Old Oct 21, 2006 | 11:54 AM
how do i got about that. they visually seem fine...nothing leaking.
Old Oct 21, 2006 | 07:11 PM
bump
Old Oct 21, 2006 | 07:26 PM
flip b18b's Avatar
Default Re: (silentdeath12886)
You can check to see if there is any fluid comming out of the struts, also you can take out your strut and undo your spring to feel the compression of the strut if it feel looser than Pamela Anderson then it's time for new struts
Reaccion
Honda Civic (2006 - 2015)
Nov 6, 2012 07:22 PM
SiR99
Jul 30, 2006 01:39 PM
hybridbmw
Jun 13, 2002 04:21 PM
