Spun Bearing
Old Oct 21, 2006 | 08:52 AM
Touge Tuning's Avatar
Default Spun Bearing
what is required to repair a spun bearing? I am being told I would need to replace the crankshaft, rod with the spun bearing and all the rod and main bearings most likely. Along with that it would probably be wise to change all the seals etc down there. Is this true?
Old Oct 21, 2006 | 02:41 PM
non-VTEC's Avatar
Default Re: Spun Bearing (Stealth1)
find another engine.
one a bearing spins on a honda crank it's junk.
Old Oct 21, 2006 | 04:40 PM
Default Re: Spun Bearing (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">find another engine.
one a bearing spins on a honda crank it's junk. </TD></TR></TABLE>
damn, wasnt the answer I was hoping for lol. Luckily I have a spare crank sitting here to replace it. Looks like time to swap to a D15 vtec lol.
Old Oct 21, 2006 | 07:42 PM
JDM94EG28's Avatar
u can mayb get the crank re-done and get the cylendor walls honed out
Old Oct 22, 2006 | 01:03 PM
non-VTEC's Avatar
there are "some" engine builders/machine shops that will machine/grind a honda crank and then fit correct over sized bearings for them.
the problem is that honda puts some kind of hard coating on the bearing journals that gets removed once someone tries to machine/grind it down. after that happens the chance of the bearing getting spun again is much greater.
a D15 is probably worth 5 bucks.......just find another engine.....
dallasyoung
Nov 2, 2011 04:53 PM
ShortbusEK
Mar 7, 2008 01:29 PM
acrocat
Jun 15, 2007 06:34 AM
